300zx vs MKIII Supra?
Originally Posted by WillEatUrSTi
Ya I mentioned that up above as well. I believe Z cars also have issues with bearings when pushing power.
Ever since learning how to drive stick I have no desire to drive a slushbox again. So an auto will not be an issue here. I'm hoping there are alot more Supra Turbo's that come in stick, it seems like most of the 300zx tt's I find on the net or read about in mags are auto
LOL with all the confusion I guess I should have put MKIII in bold caps and so on. I realize the evo would hand both those cars their butts on a road course but I at least wanted somethign that could hold it's own in that department.
Couple questions
I know the Supra motors are strong despite head gasket issues but are they somewhat comparable to the strength of the 2JZ or not even close?
Keep in mind generally a70 owners don't make the money or spend the money that MKIV owners do... there are plenty of 800rwhp+ 7mgte's, and a bunch of 1jz/2jz swapped mkiii that make the same or more
Which motor can handle more power stock for stock 7MGTE or VG?
Both around the same, I used to moderate on the 300ZXClub, and I'm a fan of both
Which cars tend to have the higher hp figures and better times modified.
I'd say they are equal again, but honestly IMO the Supra is much easier to get there
The Supra is the cheaper car but also only starts with what 220hp about that so I'd have an 80 hp gap to make up. Is power really easy to get out of these just like the 2JZ's?
230hp, 250 ft lbs of torque. You can get power HELLA easy... one of the most restrictive exhaust systems ever... full exhaust with a divorced down pipe is a 100rwhp + gain... check out becauseican.com . Also, UPGRADED stock turbo, $400, exhaust, lex afm $100, 550 injectors ? clutch and a MBC = near 500rwhp.
Maybe sport compact went about it the wrong way but I thought they had really put alot of money/effort into their Z car and on race gas and nitrous I thought they laid down in my opinion a meager 550whp around there. Is this car a spend more for less kind of car to mod?
Z's have a lot of issues imo, not easy to go single, CRAMPED *** engine bay ect
Is a later model Z car worth getting that has the VTC?
No
How are the trannys in both the Z and Supra.
Not sure about the Z's... but the R154 is pretty beefy for the supra
Thanks guys keep the comments coming and be sure to say which you would pick.
Couple questions
No
Here ya go.
i say go for the supra.... not only will it hold up some type of value but it will be much easier to work on..... have you ever seen a 300zx engine bay... its one big cluster fnck!! lol
i think the Z has an edge being a slightly superior engine as it was a generation ahead of the mkiii. nevertheless toyota did an excellent job overengineering the mkiii like the mkiv so it will hold its own. the Z is a very stout car but isnt overengineered like the toyotas....
close call here.....
Wait a minute! You guys are toting the Supra as though it were the chariot of the gods! Now i have an Mk3 and my bro-in-law has a 91 300TT and after being a hardcore Supra lover for almost 10 years i gotta say they are crap. I do all the work on the Sup and the Z and his by far has less problems than mine. People think Toyota just because its Toyota is built tough and blah blah blah, thats the 1st mistake. Never go on a reputation without back up that is where you fall. MK3s have many problems, check our forums, "An mk3 without anything to fix on it? Such a thing does not exist" is basically our motto. Every car will have its weak link, the Z is indeed a pain in the *** to work on, but better i gotta say after having ample experience with both and being a factory trained Nissan/Toyota tech
^^^ Despite this i used to work at a Toyota dealership and i hardly ever saw Mk III supras in the shop. If they did come in it was for basic maintenance. Nothing serious. I would defiently go with swapping a 1J or 2J though.
300ZXTT is really hard to work on. if u look under the hood, everything is just cramed in. there's just no room. a friend of mine has a 94.they look ok imo.
supra on the other hand is just wow.another friend of mine has a 94 6speed supra. single turbo. n since its an inline six, there's **** load of room in the engine compartment
Joe's Evo X
Sep 13, 2008 05:12 PM
OsoiCT9A
For Sale - Miscellaneous Automotive
Jan 2, 2008 09:03 PM
3000ways
Future Lancer / Evo Models
40
Oct 12, 2006 02:30 AM
EVO-8-Nate
Nov 10, 2005 04:24 AM
