Al Friedman tuning STI's
#46
Originally Posted by Noize
It is true that the disparity isn't too bad when comparing stock cars. But modded, the gap widens considerably.
First, although the STi tranny is plenty robust, the gear spacing itself is horrid. The bottom four gears are too short for even the stock power levels and are practically on top of each other. You have to go to fifth in the quarter mile, as fourth won't even do 100mph at the redline. To add insult to injury, fifth gear is extremely tall, and is capable of around a 135mph terminal speed at redline. You'd think six speed they could get it right, but they didn't.
Perhaps it is more to do with which you're used to. When I go from my evo to my sti, I need some time to get into the swing of things regarding shifting right and such. It doesn't take very long, but I'd imagine that if I jumped from one straight to another, I'd feel a bit iffy.
Second, the chassis in the STi is a lot more twitchy and nervous than the Evo. Obviously, this can be corrected with a little suspension work, because there are people who are campaigning them with great success. I just like the chassis a lot better in the Mitsu. Our turn in is a lot more crisp, there's less understeer, and the steering rack is lightning fast.
Next, the biggest problem: The STi's engine and turbo setup. The stock ihiVF39 turbo is awful in comparison to the 16G, which we all know already. The intercooler is top mounted -which is more efficient at low power levels for a boxer engine- but limited by space, doesn't cool its core as well, and is very prone to heat soak. Going to a front mount is a huge problem, because the pipe routing required to plumb it is brutal. All the advantages of the short IC piping are wasted, with huge upper and lower pipe paths that make the Evo path look short. This is added to all the pre-turbo piping that already exists from the boxer H motor's configuration. Even with the larger 2.5, this is the recipe for something that sucks: LAG.
The jury is still out on the longevity and strength of the EJ257. Some STis spin rod bearings even before 400whp, while others make more and seem to be just fine. I never cared much for Russian Roulette, so I'm not even loading that gun.
I don't want this to spiral into another **** fight but in all seriousness I think the difference between the two is down to preferrence. I'm sure we can find subaru forums with posts saying why we should all cry and sell our evos. I posted a link on this thread a few posts back with dynos of both cars. It's interesting and shows they're pretty even. I have both and while I've modded the evo quite a lot, the sti is catless but otherwise stock.
Obviously I am not talking about big power tuning - which I don't think Carlos had in mind - and really once you get into strokers and turbo kits, it's as much to do with tuners as the car itself.
Sorry to have gone on for so long...
#47
Noize, I love the way you expressed yourself on you last comment (last page), you really put a great comment.
X838NWY. I agree, it is the matter of choices. I am not planning on modding the STI too much. I would mostlikely will get a full exhaust, CAI and MBC. I already have a extra SMC kit waiting for install.
I just want another nice daily driver and I think the STI is a street friendly ride. I saw a couple of used 06s, I just need to throw some numbers and see if I decide on the 06 or a use 05. Either way I think I wouldn't be dissapointed.
I would mostlikely give a try with Al and see what he can do on mail in flash. I haven't heard from him on this topic yet but I would still give him the benefit of the doubt as I think he is a master of tuning.
The bigest downside on the STI is the turbo size and how far the turbo is located. Additionally the TMIC gets all the heat soak and if you decide to go FMIC you must accept that you are installing a minimum of about 10 feet of IC piping which makes the eficiency nule.
On turbo and intercooler location the Evo is a winner. Even the turbo gets cool down as you roll and you also get the heat out of the engine bay though the hood opening, we can't argue that on that aspect the Evo has a win to win situation.
On the other note never understimate the STIs, you can always slap a cheap *** VF22 for $500 and you would be surprise. Alcohol kits are also making the torque megahuge on the STIs .
Carlos
Carlos
#48
Carlos, here's something to whet your appetite, if you're into this sort of thing:
Prodrive (Japan) cat back for the Sti:
http://www.prodrive-japan.com/products/muffler/
![](http://www.prodrive-japan.com/products/muffler/img/muffler_gdb.jpg)
^I'm getting this one (already have HKS high flow cat).
Prodrive (Japan) coilovers for the Sti:
http://www.prodrive-japan.com/products/suspension/
![](http://www.prodrive-japan.com/products/suspension/img/newsus_gdb.jpg)
And cos you said you didn't want to mod it extensively:
http://www.cosworth.com/shop_range.php?typeid=42
They do pistons (obviously), cams, conrods and heads for the 2.5 and a few other things like this:
![](http://www.cosworth.com/uploads/1143667817450.jpg)
For $5,150 you get:
<LI>New Subaru EJ25 STI Engine Case
<LI>New Subaru STI Forged Crankshaft
<LI>Cosworth Forged Connecting Rods
<LI>Cosworth Forged Pistons
<LI>Cosworth High Performance Piston Rings
<LI>Cosworth Race Spec coated Tri- Metal Bearings
<LI>Balanced and Professionally assembled
Billet Crankshaft optional
It's almost worth it....
For $5,150 you get:
#49
![EvoM Administrator](http://forums.evolutionm.net/images/titles/admin.gif)
Originally Posted by x838nwy
Strange, this. I have the 6-speed on my 8MR and another 6-speed in the Sti. I don't seem to think either have it 'wrong', in fact they're both very well spaced IMO. I don't to drag racing so I can't comment on what happens on the strip, however.
x383nwy-
With respect, you cannot compare an awesome EJ207 powered S203 Impreza to our dumbed down US STi with its low revving EJ257. Have you actually driven a US Spec STi? Because if you have not, your comparison is magazine racing at best. If you have, then look at the evidence I'm providing below more closely.
The gear spacing issues in the STi can't be ignored. Here are gear speeds of these cars at their indicated redlines (7000rpm):
US Evo VIII 5 speed: 40,60,83,113,162
US VIII/IX 6 speed: 40,60,82,107,135,169
US STi: 37,56,76,99,138,177
In essence, not only do you have to shift the STi to 5th in the quarter mile, but you would need it road racing as well. You can get away with never using fifth in an autocross, but with our lower redline STi, you'll need it in most other professional forms of racing. If you notice, there's nearly a 40mph gear spacing hurdle, and it happens around 100mph. That's hardly nice for acceleration at all.
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
Moreover, almost all the Evo flashes move the rev limiter up to ~7800rpm, and this is completely safe on the stock driveline. You can't safely accomplish this with the STi, as the piston speeds would be too high, and its beyond the usable powerband of the engine anyway.
This is perhaps a result of the sti's wheelbase being shorter than the evo. In city traffic, I prefer the sti. IMO I think it will be hard for an evo to beat an sti in a gymkhana type event (both stock). As for over/understeer, IMO both understeer. The Sti (up to 05 at least) oversteers slightly on throttle while the evo kindda stays the same. To me, it's more a preferrence thing.
The evo does turn sharper but to _me_ it's more nervous than the sti.
As you pointed out, the tmic has its advantages. With ic's there's always a trade off between cooling effect/pressure drop/transient response. The sti's philosophy seems to lean towards the last two and there are good reasons for this. The effect from cooling is rather slight compared to the adverse from the pressure drop.
I've seen cars that lose hp from getting afterarket intercoolers (Carlos seems to have sufferred the same).
![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
All in all, with the stock turbo, I don't think the tmic is an issue at all.
Because of its setup, it is easier to get the turbo/ic sizing wrong in an sti than the evo which I suppose is why the sti is normally perceived to have more lag.
I would put things like spun bearings and such down to installation errors. To be fair, evo's are very easy to work on but yet we see people with broken engines all the time.
![](http://www.we-todd-did-racing.com/wetoddimage.wtdr/wNzA3ODAyNnM0MTNkZmQzMXk1NDE%3D.jpg)
#50
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
#51
Noize,
There is one thing which is a little problematic to our discussion. Mainly I'm probably talking about more of the JDM 2.0L Sti and guys from the US (which makes most here!) are talking about the 2.5L. I have not driven these 2.5L machines and as such I don't know if there's any difference in gearing. [To be sure I'll see what mine does at 7k in various gears and let you know.] It would be rather strange IMO for Subaru to change gear ratios in only one gear. I can't see how they would go through all that extra effort and did something silly to the ratios.
Anyway, if we take the 7k rpm speeds as a basis and assume we shift accordigly, rpm's as we start each gear is as follows:
evo 5 speed - 4,666/5,060/5,142/4,882
evo 6 speed - 4,666/5,122/5,364/5,548/5,869
sti 6 speed - 4,625/5,157/5,373/5,021/5,458
The difference is around 500rpm. Now if you have sufficient torque at 5,000 rpm, I don't see much wrong with this and by the looks of things, it seems they've geared for it. Obviously as real-life shifts aren't instantaneous, you probably get into 5th slightly lower than 5,000rpm which might be a problem. More likely however is that often tuners aim for big hp numbers, sometimes at the expense of torque and power band. If they're not careful, this will cause problems with this particualr set.
I be fair, the S203 suspension comprises of Sti linkages and 4-step adjustable struts and Sti springs. Now this might sound like a lot but save the linkage, from the other sti's i've driven, the stock strus aren't all that different. In fact the difference between the non Bilstein evo's and the MR's is waay more pronounced. As for turning, personally, the evo's steering is quicker and lighter but its turning circle is larger and it understeers more on throttle. Nothing you can't drive around, mind.
The thing about the turbo charger, I agree that the pulmbing going toward the turbo on the sti makes it inherently disadvantaged. And this has been an area of quite intense development by subie themselves. The various incarnations of sti's over the year pretty much all have different manifolds, up pipes and down pipes which is real confusing. The upside to all this is that the path from the intake all the way to the intake mani is very short. I guess they're betting on gaining from that side of things.
With the 2.5, the situation can only improve IMO. The additional capacity should be able to offset much of the lag. Assuming of course, that Subaru North America haven't done something silly I don't see why the 2.5L if anything isn't potentially better than what I have....
One thing I suppose is that JDM sti's alone there are between 6 and 9 versions depending on who you talk to and there are versions where the are somthing silly like 3 catalytic converters in some strange places (like the up pipe) and is likely to be the case given some emission regs in the US. Again, this is nothing that cannot be overcome but might be something unique to the States and is perhaps why your sti's are a little crapper
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
#53
Noize,
Sorry to dig this up again, but just remembered to look at the speedo on my Sti at 7k rpm in 6th. The needle is right at 125mph.
I couldn't remember the number you posted here (well, I've just seen it now, US Sti = 138mph) and seems quite a lot different. Unfortunately cos I didn't know then that it was different, I didn't look at it in other gears.
It would be likely that other gears are different also since if 4th is the same as the US Sti then we'd be talking about 5th gear starting at 5,566rpm if you shift from redline in 4th which does seem a little high.
This is really quite strange and I can only think that Subaru has chosen to have different gearing for the US market for reasons of mpg figures - where perhaps cars are tested at 'standard' speeds which probably just happenes to be a particularly bad point in the jdm sti's operating curve. I mean, according to the US figures, 55mph in 5th is at 2,790rpm whereas the JDM would be around 3,080rpm....
fromWRXtoEVO
30
Dec 27, 2014 08:19 AM
boomn29
32
Apr 30, 2009 04:00 PM
