Car will not run... so annoying..
Ok, 1st off, I appologize, this is not related to my Evo but I figured there are plenty of knowledgable ppl on this forum. My 98 Nissan 200sx has been giving me issues for the past few months. It will occassionally not start or bog at a certain RPM, etc..
I replaced the MAF, I replaced my plugs, wires, cap, rotor, fuel filter and non of this fixed it. Well, unfortunately the car wont start at all right now... I replaced the fuel pump yesterday thinking this was the issue... It didnt start, so I pulled my upstream o2 sensor and tried again... it got running. Before I replaced the fuel pump this alone did not work however.
Keep in mind my car is one of the Nissans with that S***ty Pre-cat right off the exhaust manifold. Does this sound like a fuel issue? Or could it be a clogged cat? I'm truely lost... Tested everything.... MAF, TPS, Camshaft position sensor, and replaced everyhtin I listed above... No luck.
Odd thing is after I got the car started last night, I shut it off, put the o2 back in; it ran 20miles with my buddy driving it (I was with him). After shutting it off, we came out to the car in the morning and got it stated after about 5 tries, and now I can't get it running at all....
IDEAS??!?!?! I'm getting really frustrated and since the Evo is on downtime for about a week I really need my daily driver...
on my z32 twin turbo, i had a fuel pressure regulator, or fuel damper, that had a pinhole in the rubber diaphragm that would cause it to flood out, it would not start at times and would bog from too much fuel. not sayin thats it, but check for fuel in the intake.
Originally Posted by japspec4g63
I know you replced the plugs and wires, but are you getting spark?
maybe a computer or wiring issue, any codes? does it have fuel at the rail? how does it run when started? perhaps a sensor? timing belt slipped? maybe the car jumped timing....... not enough info.......
u tested the maf? how so? try starting it without the maf connected, and i would also try searching the junkyards for another ecu. How did it run when it was running. Decent or just barely running. ^^ if the car jumped timing the head is most likely trashed but this is unlikely cuz you said it did run. also i would reset the ecu we need more info!
hooliganSKATE
Jul 16, 2015 06:21 AM
duranvw
Oct 4, 2012 06:37 AM
killerpenguin21
13
Apr 7, 2012 04:49 PM
OneEyedJack
47
Sep 9, 2010 07:30 AM
