Revolution (GT42R Killer) Project Build
Just thought I would start my own thread of the winter build up. Vehicle 1997 Eagle Talon, weight 3300Lbs with driver, no nitrous best Et 10.6 best Mph 142Mph on old setupl
A brief Video compilation from the past season!
http://talongt66.4t.com/2008%20PROMO%20VID.wmv
Much more to come!
JM Fab SMIM
New Weldon Pump and filters
4 more 1700cc injectors (8 in total)
Some AN 24 line fittings
Custom made pistons
Custom made rods
Billet Crank
Protype Cams
Springs/Ret
Torque Plate made to my specifications
Custom built Dual Ball Bearing Turbo
Parachute
and some other odds and ends!
Custom Pistons and wrist pins
Custom length Rods
JM Fab Torque Plate
Much more to come!
JM Fab SMIM
Custom made pistons
Custom made rods
Billet Crank
Protype Cams
Springs/Ret
Parachute
Custom length Rods
JM Fab Torque Plate
Getting ready for the new motor combo!
I would say progress pics, but in actuality the car is getting more and more torn apart. Rewiring most of the interior.
Removing the roof off the car! Can you say convertible.
Any reason you used the Marine version of the 2025 pump? Also it's only rated at 1400hp FI not 2000hp. What bsfp do you plan on running as the pump is rated to max out at 80psi? I noticed the two fuel filters. I couldn't tell the part numbers from the picture but I'm assuming you got one 40micron for before the pump and one 10micron for after the pump. What AFPR do you plan on running? Make sure to post pictures of how you route it all up. Looks good!!! Very impressed with your car and can't wait to see what it does with the new setup.
