My 300zx won't rev above 2500rpm
Registered User
So as well as owning a evo I also own a 300zx, and lately it wont rev over 2500rpm. Some one told me it was the MAF, but they had no idea how to test it. If anyone has any info, it would be really appreicated.
Thanks
Thanks
the maf will throw a code most of the time (Air/ fuel metering malfunction) or system lean air/fuel metering... you can put a scan tool on it and see what the barometric pressure is the se if the maf isnt reading right...but if it wotn rev over 2500 there should be a code stored
That person is right it most likely is the MAF sensor.
NISSAN 300ZX Mass air flow sensor requires no regular maintenance. On mass air flow sensors with a sense wire, this wire can become contaminated with dust particles. These particles can be removed with automotive solvents that are safe for the use on mass air flow sensors. NISSAN 300ZX mass air flow sensors are commonly misdiagnosed. Before replacing the mass air flow sensor check for air leaks in the connecting air ducts and intake manifold. These leaks can cause similar symptoms as a malfunctioning mass air flow sensor.
Here is a link to where you can get a service manual to check the MAF with a ohm meter.
http://www.pdfoo.com/result-1992-nis...e-manual-.html
Good Luck!
Chris
Good Luck!
Chris
Good Luck!
Chris
Good Luck!
Chris
It's either the MAF or something affecting the MAF. It sends a voltage reading to the ECU to determine the mass air flow. Using a multimeter, you can measure the voltage at the MAF and it should read roughly 1.4-1.7V at idle, or really close to that range. If any of the piping is loose after the MAF where air can leak in, it'll trip the MAF code and cause the car to run in limp mode; hence the 2500rpm limit. I'd guess either a loose connector or a loose pipe after the MAF.
Registered User
Just wanted to thank you guys for all the help. It was the MAF. And to my luck, I'm getting a free one tomorrow. Local guy just flipped his twin turbo Z and is giving me some of his parts before he scraps it.
300zx MAF Test
Test te MAF connector B (it is lable on the MAF-the small white wire) for voltage. It should 0.8vdc. Start the car and let it run to operating temp. With it idle check the voltage again. It should read 0.8-1.5vdc. Any reading lower or higher then replace the MAF.
CT9A PR
May 27, 2014 10:56 PM
Evozster
14
Oct 10, 2007 05:58 AM
