The OTHER rides.....
Just bought the Evo in this month's Jan 09 Dsport mag, so I figured that qualifies me to post. haha. Here are the other rides.
- 2006 Gallardo SE
- Verde Ithaca
- E-Gear Trans
- Engine Removal and Disassembly
- L.A. Sleeve Steel Cylinder Liners
- Carrillo Forged Rods
- Custom 9:1 CP Forged Pistons
- Polishing of Crankshaft Journals
- Connecting Rod Bearings- Main Bearings
- Balancing of Rotating Assembly
- Blueprinting and Assembly of Engine
- Heavy Duty Clutch and Pressure Plate
- Twin Water Cooled Dual Ball Bearing Garrett GT-35R Turbos
- T04 S compressor w/61mm inducer and 82mm exducers
- Garrett T3 four bolt discharge housings w/63 A/R ratio
- Two Tial 44mm wastegates
- Two Tial 50mm Blow Off Valves
- Custom Made Stainless Steel Turbo Midpipes
- Custom Made Stainless Steel Turbo Downpipes
- Custom Made Stainless Steel Exhaust System
- Stainless Steel Turbo Oil Feed Lines
- Stainless Steel Turbo Oil Drain Lines
- Colder Heat Range Spark Plugs
- High Flow Turbo Air Inlet Plumbing
- High Flow Turbo Air Discharge Plumbing
- Spearco Water to Air Intercooler
- Intercooler Water Pump
- Intercooler Water Reservoir
- All Braided Lines and Fittings
- 255 lph in tank fuel pumps
- Upgraded Fuel Injectors
- K&N conical air filters
- Upgraded Gaskets and Fluids
- Mark Williams Halfshafts
- AEM EMS
- Superleggera Carbon Rear Diffuser
- Carbon Decklid
- Larger Brembo Rotors
- Full Body Clear Bra
- K40 Calibre In Car Laser/Radar
- HRE 843R w/Textured Monoblock Finish
- Hoosier A6 315/30ZR19 rear
- Hoosier A6 235/35ZR19 front
- 2006 Gallardo SE
- Verde Ithaca
- E-Gear Trans
- AEM EMS
- Carbon Decklid
Engine:
Virtual Works 3.4 stroker
CP Flat Top Pistons
Carillo Rods (upgraded carr bolts)
Crower Balanced Billet Crank
Clevite bearings
ARP main studs
Program Billet mains
Line honed block
Fully polished and ported Virtual Works race head
+1mm Crower valves
Ferrea dual spring/retainers
L19 Head studs
HKS 280 Cams
Unorthodox Cam gears
Unorthodox Pulleys
BoostLogic crank pulley
BoostLogic Billet tension
Virtual Works Intake Manifold
Accufab Throttlebody
Virtual Works Modified Oil Pump
Virtual Works Modified Water Pump
Toyota P/S pump (new)
Power Enterprises Kevlar Timing belt
Power Enterprises Kevlar Serpentine belt
Chromed Valve cover
Virtual Works Breather Kit
Powerhouse Polished Spark Plug Cover
TTC Polished Brake Cap
TTC Polished Washer Cap
TTC Polished ABS Relay Cover
Greddy Billet Oil Cap
ATI Lexan Spark Plug Cover
All Bolts Switched to Stainless Allen Bolts
Lines Converted to Braided
Polished Fittings
Extensive Chroming
TRD motor mounts
Turbo + Exhaust:
Virtual Works turbo header T6
Tial 44mm wastegate
GT47-88mm Dual Ball Bearing Turbo (polished and coated) T6
Virtual Works anti-surge turbo insert
Virtual Works Modified Water Neck (to fit large frame turbo)
Virtual Works stainless and Coated Downpipe
Custom SP (chromed) 6” cold air intake
Boost Logic T6 Turbo Blanket
HKS racing bov
HKS Hiper Titanium Exhaust
Cooling:
Fluidyne Supra TT radiator
Sound Performance 5 inch race Intercooler
Custom Virtual Works 4” intake piping
Virtual Works Upper and Lower Intercooler Strap
Upper radiator hard pipe
Lower radiator hard pipe
Upper radiator cooling plate
Upper Radiator show plate
Trans + Clutch:
6 speed PPG Dog Engagement Gear Set
Tilton Carbon Triple Disc clutch
Custom 1pc steel driveshaft (cnc’d ends)
Virtual Works Driveshaft Loop
TRD LSD
TRD Trans Mount
Fuel System:
Weldon 2835 Fuel Pump
Weldon Fuel Pressure Regulator
Virtual Works Dual Fuel Rails w/1000cc Injectors
Custom AN Fuel Lines
Suspension:
TRD Coated Sway bars
Koni Coilovers rear
Virtual Works Fully Custom One of a Kind Heavy Duty Rear Suspension
Virtual Works Mini Tub
Tein Flex coilovers front
Tein EDFC controller
Cusco carbon rear strut bar
DoLuck Cross Bar
Electrical:
Titan Darin Modified Engine Harness
Motec M800 Engine Management
HKS DLI Twin Power Ignition
Blitz turbo timer
AEM Tru Boost Gauge
Defi Water + Oil Gauges
AEM Serial Gauge
FJO Wideband gauge custom mounted
TRD 10K Tach
Trunk relocated battery
Brakes:
Brembo 14 Inch Big Brake Kit Painted Lambo Verde
Slotted front + rear Brembo rotors
Goodrich Stainless brake lines
Wheels + Tires:
HRE 597R 18X10 front
HRE 597R 18X13 rear
Nitto NT555R Drag Radials rear (335/30/18)
BFG Gforce ZR front (275/40/18)
Interior:
TRD Steering Wheel
TTC Drilled Performance Pedals
10% Tinted Windows
New Carpet 33,000 miles
Custom Supra Black Floor Mats
Sparco Milano 2 seats
SP Rear Seat Delete
Exterior:
DoLuck Late Model Front Bumper
Bomex side skirts
Clear Signal Markers
Smoked Side Markers
Smoked Taillights
C’s Short Throw Shifter
MVP Polished Aluminum Shift Knob
3M Clear Bra
Awesome cars!! Question, did you took your car to a shop in Lewisville near Dallas named Quality Motorsports? While I was there in late August the owner told me that they did a custom install of a Twin Turbo Lambo at their shop.
Frankly I don't think there are many Lambos in the USA with a set of twin turbos so that why I am asking.
Carlos
Carlos
