My LS2 350z--PT88 single turbo build.
#37
Got some more work done today...
Cross over is just about done..just need to weld in o2 bungs and figure out what I wanna do for a wastegate
Downpipe started:
Radiator mounted too..seems to fit just about perfect:
Downpipe started:
#43
Heres some of the new fuel setup. The pump supports up to 1500hp. It will be just about completely hidden under the Vette FR covers except for the cross over in the back. I have -10 going to the pump and -8 feeding the rails with a -6 return.
And heres the pump setup with the filters on it almost done. I screwed up the fitting going from the tank to the pump so I had to order a new one. Once I have it ill be able to pressure test the whole system. The whole assembly sits completely tucked up in the frame rail and the bracket is tigged to the frame then painted over. Its never gonna come off and I wont have to worry about bottoming out ripping anything off.
