Water-pump failure signs?
So im not 100% this is the section to as this question but I didnt see a better one...
Im curious on people's opinion or diagnosis. I have a 1994 Accord with just under 200k on the clock.
Heres what happens... After the car warms up the temp guage seems to stay a 1/8" under the midway point. If i get to some stop sign or park the car but keep it running, after about a 1 min the temp gauge starts to go up pretty fast. Maybe in a matter of 15 seconds it would reach the top if I were to let it.
Heres the interesting part. If I hang the RPM's above idle lets say at about 2kRPM the temp level goes back to normal. When I stop it starts to go back up. Needless to say when I am driving on the interstate or driving in general the car keeps temp at a normal state.
Would this be water pump related or thermostat related? From what i know about water pump failure is that its either the pulley bearing or the seal itself. I dont hear any unusual noise that would indicate bearing wear and there is no loss of coolant. It has also been doing this for a couple of months now so I would assume that if it was worn bearings then it would have ceased by now. If the problem is the thermostat then it still doesn't make sense to me. I was always under the impression that thermostats are supposed to fail in the open position. Making the car run under temp. In addition since its a mechanical thermostat intermittent operation doesn't make sense to me either.
I thought maybe the water pump has lost some of its efficiency and only works "well enough" when its spinning a bit faster?
Thanks for your input guys. Ill probably replace the thermostat this weekend it just a PITA because I believe it located on the bottom not top...
-Ethan
-Ethan
Sweet. Thats kind of what I was thinking. I guess i just felt if the thermostat failed it would just run cold because there was constant circulation. Anyway Ill swap it and see. Thanks for the info!
Raceghost
Feb 11, 2017 10:27 PM
EvilTechnology
Jun 24, 2015 09:22 PM
