STi W GPMoto GT32 turbo kit doing donuts (vid)
No idea on the HP... The Clutch doesn't hold on boost unless the tires don't. Lol 50+ off redline launches.
Anyhoo the mods are
GPMoto GT32 Kit (Garrett GT32 turbo, Modified GPMoto header for twinscroll, modified GP Moto turbo back, GPMoto intake, + misc stuff needed)
Unichip w driver module for FCD
Walburo 255LPH pump
AEM RRFPR
Apexi Coilovers
Greddy EO-1 boost controler
GPMoto upgraded radiator
BTW 23psi at 2,900 rpm in 5th and 6th.
Anyhoo the mods are
Walburo 255LPH pump
AEM RRFPR
Apexi Coilovers
23 psi!!!, I thought the sage maximum boost is 15psi on the subie engine because UR-Racing have a turbo kit on the car and they set it at only 15psi BTW: it's a Garrett T3/T04E Ball-Bearing
I've been running 23psi on the old AVO500 I had for quite a while. Really right now I am limited to the boost I can run, not by the motor, but by the injectors. I have to run 90psi peak fuel pressure to get the stock injectors to work at 23psi.
So likely in the near future I will pick up a set of bigger injectors, some colder plugs, and a few extra PSI boost.
