Evo powered tube chassis Mini Cooper build
Fun fun. are you going to use the stock half shafts? They may be a limiting factor with wheel articulation as they are already at some intense angles being stretched forward.
You're also going to be pretty nose heavy with that setup. Just a suggestion, you may want to consider running the coolers in the back. Perhaps an air/water setup, with a heat exchanger and radiator between the back wheels with tunnels in the floorpan to feed them. That might clear you some front space.
Just saw you are in Simi Valley. I worked with a turbo company out there for a while. Fun place to be working on cars.
I seriously considered putting the radiator in the back but by the time I get the rear diff/suspension, the fuel cell, and the battery back there I am out of room.
I am guessing you worked for turbonetics
Got some more pics for you guys
Mini body after I cut the bottom out of it
Bunch of random cage and overall pics
Front and rear suspension. The new front struts came with camber plates and I built the upper mounts with caster adjustment. In the front I am using stock EVO lower a-arms and BR racing struts. Rear suspension uses the stock forward lower link and all the other links I built from scratch. rear shocks are QA1 coilovers. Stock EVO sway bars were used front and rear.
Hacking up the wiring, I removed everything from the harness that was not needed to make the car run, deleted ABS, ACD and all the other crap. Then I condensed all the fuses into the underhood fuse box and eliminated the interior fuse box. While I was there I rerouted all the wiring that ran through the drivers fender and ran it through the firewall bulkhead. Once all that was done I rebuilt all of the lighting, wipers, horn ect. wiring back into the harness.
Probably somewhere north of 700hrs. That is including some but far from all of the design time. It will leave here a running/ driving vehicle but it will still need a fender flares and a bunch of body work.
