ZL1 auto trans - fastest shifting?
If it's a slush box with clutches and sprags and planeteries, I can see how it can shift faster.
The PDK is a true twin clutch box with a gearset. Those can only shift so fast and be reliable in a street car.
To me the fact it is a 10 speed is more remarkable. Like....how much gear "leverage"
do you really need with a 650 ft/lbs rated motor. It is that much closer to a CVT but appears to be able to handle allot of torque.
I want to test drive one...... I bet it is impressive.
The 10 sped is also more about efficiency than speed.
It's not really so much about better gearing in the middle. It supposedly has a very short 1st gear, 2nd gear is more of a "normal" first gear ratio, and 7-10 are all overdrive/freeway gears. So on a track, you'll likely be using 3-7.
Heck we can now afford to have less slip in torque converters and a "granny" first gear to get out of the hole.
Yes that is what I would expect. Again...being "closer" to what a CVT can provide through a constantly variable ratio you keep the powerplant in it's optimal (most efficient) working condition. Make a graph and plot a 10 point line and it provides you much greater resolution.
