Mk V Supra - My Evo's Replacement?
#2461
I decided a year or so ago that I wont do anymore track time with my Evo. It'll just be an AutoX car until it gets retired and converted back into a street car.
Maybe one day Mitsu will get lead by an enthusiast again and they'll pull an RX7 on us with new production of old parts.
kaj (Mar 17, 2023)
#2462
yea its all the drivetrain and stock parts that are hard to get. even stuff mitsubishi do still make like crownwheel and pinions can be an 18 month wait. Which sort of forces you down the billet or aftermarket route. i think if your that far down the rabbit hole then youll be pretty insulated. although things like engine blocks are even becoming hard to find.
I do still want to do a supra build from a shell and put a different motor etc in it. Maybe one more good year in the evo try win a championship then sell it and start on a supra
#2463
#2464
#2465
Id want to put a traditional sequential or transaxle behind it and im thinking something like a 1jz/2jz or an LS etc.
Even possibly a k20 or 4g63.
That and i can pick up an empty damaged shell much cheaper than i can get a running car
#2466
The only stress I saw on a car during track days is heat. And even that wasn't a problem; my car managed it perfectly.
#2468
#2469
Finally started tuning my Supra. It's making about 130whp over stock now after a couple days of tuning. I'm currently hitting up against a passive load limiter that is taking the top end down so as soon as I figure that out it should be making a bit more.
One thing is for sure, it sure as hell woke up. The car is a beast now and I probably have about 80whp more or so to go to get to where I want it, and this is just on 93 octane.
I am ramping the boost in so the tires don't just evaporate when I go WOT from low RPM. I also tuned the throttle mapping and it's SOOOOO much better, much more linear feel. There is also a table that loads up boost behind the throttle plate when it sees a shift in requested throttle to help make the car feel more NA when stock. It got a little surgey with the upgraded turbo so I reduced that as well. Car feels fantastic.
Here is a log if anyone is curious: https://datazap.me/u/razorlab/mysupr...1&zoom=121-268
@Lumpy Sticks The Verus splitter clears my driveway exit just fine, unless I don't go slow then it slams into the ground I found out. lol. I also almost annihilated it driving into a gas station. Need to learn it's height limits! hahah. The supra got attention before and I found out the last couple days, it REALLY gets attention now. Perfect for an introvert like me... 🙃
#2470
Is the ECU's torque logic fairly simple to grasp coming from tuning Ecoboost stuff? I found ecoboost to be fairly easy once you found all the torque limiters
#2471
So far it seems pretty straightforward. Requested torque turns into requested load turns into requested boost. Fuel tuning is set and forget basically. Boost dynamics is the most complicated but if you understand modern PID systems, it's logical. There is also compressor map tuning that needs to be done when you upgrade the turbo. The closest thing to an actual WGDC table is the compressor map table.
#2472
#2474
rustykan (Mar 29, 2023)
