AMS Flash tune date April 28 and 29 w/dyno
Here is the official AMS flash date for April 28th and 29th.
This even will be held with our good friends Atlantic MotorSports.
Their address is:
8001 Queenair Dr.
Gaithersburg, MD 20879
They are cutting us a CRAZY deal for dyno time on their AWD Dynomite Dynomometer. It will only be $65 per car!
I will be available for 5 custom flash tunes on the dyno per day. If we need to we can squeeze 6 in a day once we start getting all filled up.
The flash itself will be $395 for a first time AMS custom flash.
For returning AMS flash customers it will be $200/hr (less than 1hr expected)
Base flash customers will be $180
I will need you to give us a call and send us a deposit so that we can confirm your time slot. You can either put down $100 for the deposit or pay in full when you call. If you wish to pay the remainder in person you will need to bring CASH.
Just to clarify, total cost with dyno time for a first time custom flash will be $460!!!
For additional information on what is included in an AMS flash, please visit this website that I have setup specificly just for this occaision . http://amsflash.com
Time slots will be as follows.
Saturday April 28th:
Custom Flash
9am-1030am: kmcconn9 Deposit
1030am-12:TURBevO8 Deposit
12pm-130pm:MREvolution06Deposit
130pm-3pm:Marque Deposit
330pm-5pm: Jason H Deposit
5pm-530pm: Deezee PIF BaseFlash Test
530pm-7pm:
Base Flashes
Their address is:
8001 Queenair Dr.
Custom Flash
530pm-7pm:
Base Flashes
For anybody that does not want to click the link above.
AMS Base Flash
Base flash for your current list of modifications. This is also followed up with a quick road test with logging to ensure that everything is working properly. You can expect at least a 20whp and 20ftlbs torque gain. We will be doing these all day, in-between the custom flashes on a first come, first serve basis. $180 (CASH ONLY)
All base flash cars must have:
Fuel Pump (Recommended)
Stock injectors
Stock MAF intake pipe
Stock Turbo
Stock Fuel Pressure
Benefits of the AMS Flash :
RPM limit increased (customer specified)
Set 2-Step launch RPM (customer specified)
Boost control (Custom and Base flash)
Raise fuel cut to safe level, or remove completely
Air/Fuel curve optimization
Timing CURVE optimization
MIVEC Tuning on Evo 9’s (Custom and Base flash)
AMS Custom Flash
This Item is for putting a deposit down to start a custom flash day in your area, OR to join a custom flash day that has been setup already. We will need at least 5 people to justify coming out to your area to do custom flashes.
You have the option of leaving a deposit ($100) or in the drop down box below, you can select to pay for the entire appointment at this time ($395). If you are only leaving the deposit, you must bring CASH to the appointment, as it will be our only means of collecting the money on the spot.
You will need a complete modification list written down in the comments section of the checkout pages.
Here is a breakdown of the pricing structure and what is included with the flash.
Improved idle with cams
Custom flashes will be full tuning of your vehicle’s A/F curve and timing curve. Also, for the EVO 9 the MIVEC timing will be optimized. As you know every car is different, some are very different, and this will bring out the very best in each car. Unlike the base tunes, they will be adjusted for your specific car to extract the most horsepower and torque possible. Actual numbers will depend on the modifications to your car. Each custom tune will have its own 2 hour time slot. $395
AMS Base Flash
Stock injectors
Stock Turbo
Stock Fuel Pressure
AMS Custom Flash
As in draining out all of the pump gas you have and refilling the tank with your gas of choice? No, it does not include that service.
If you want me to make it a little more agressive for you, I can do that.
Thanks
Chris
