60K mile service
60K mile service
I'm sure some of you had your 60K mile service done. Where did you take it and how much did it run you? I'm looking for a good service department to complete this service.
TIA -
Johnny
TIA -
Johnny
Here is what we have to offer, thanks!!
LMS 30k Service And Timing Belt Specials
First up is the 30k, 60k, 90k, 120k services.
This service includes the following:
oil & filter change (10w30 synth oil & mistu oil filter)
replace spark plugs
replace coolant
replace all drive train fluids
flush brake and clutch fluids w/dot 4 (unless other is requested)
replace or clean air filter (k&n style)
inspect radiator hoses
inspect serp belt
inspect front and rear brake pads, rotors, and brake hoses
check all lights and wipers
check tire pressures and condition
rotate and rebalance tires (if needed)
check suspension
check exhaust
add redline si-1 fuel injection cleaner to fuel system
lubricate door hinges
road test vehicle
$575.00
We use Redline Light Weight Shock Proof in the trans (unless other fluid is requested)
We use diaqueen in the t-case with no exceptions
We use a LSD GL-5 80-90wt fluid in the rear diff (unless other fluid is requested)
We use NGK BPR7ES spark plugs gapped for your boost/power level (unless other plugs are requested)
We will use K&N cleaning kit unless a new filter is requested or a stock filter is needed.
We will pull your tune and spot check it for any obvious problems, and change your 2-step, rev limit or other low level changes for free, if customer requests
Service Upgrades (For An Additional Charge):
Redline water wetter cooling system additive
BG 44k fuel injection cleaner
Ignition wires
Irridium spark plugs
All services can be modified according to specific customer needs and prices will change accordingly.
Timing Belt Services:
Labor Included
New OE timing belt
New OE balance shaft belt
New OE water pump
New OE timing belt tensioner
New OE serpentine belt
fresh engine coolant
out the door price of $1025.00 w/water pump or $725.00 w/o pump
OE quality aftermarket parts also available for $825 w/pump and OE tensioner or $625 w/o pump and still using OE tensioner. This is one of the most important services that you can do to maintain your evo to save you thousands of dollars in engine repairs. Also if you get cams and headstuds installed at the same time as a timing belt job it's only a extra $120 in labor.
If you get a timing belt job and a service receive and $80 discount.
PM me or Lonnie@LMS for any questions
replace spark plugs
replace coolant
inspect serp belt
check suspension
check exhaust
road test vehicle
$575.00
Ignition wires
Labor Included
New OE timing belt
New OE water pump
Lonnie...so far I've been hearing good stuff about your shops from a large number of Evo owners in the area. I'll probably head down there before the end of the month for the 60k service.
Bringing this up from the dead... I searched and found this old thread while looking for shops around NOVA to do a T belt and 60k recently. I Just got my 60k and T belt done at LaScuola Motorsports. Wow, all I can say is the car feels brand new (even after buying it used haha). Great customer service, Lonnie contacted me during the job to let me know about my Trans situation and gave me options. For the price, I def feel it's the best for all the service done to car and you can tell the knowledge and honesty is there.
I would def reccomend LMS and will be going back for some work in the future.
Thanks
Thanks
Thanks
Thanks
