Oil temperatures in the Michigan region
I just finished hooking up my Defi D oil temp gauge, and I'll be finishing my oil pressure gauge the next time I do an oil change.
What is the maximum and minimum oil temperatures that you guys are seeing with this weather. Just wanted others inputs to reference from. I want to make sure everything is working ok. Thanks.
If you have an oil pressure gauge as well, what oil pressure should I expect to see at the gauge?
Hey D...
did u use an adapter plate for the oil temp and press gauges? Too lazy to install my setup, so I still haven't done it. I'm actually thinking of NOT installing my other gauges till next year, maybe. done too much to the car already and I haven't hit the 1 year ownership mark yet.
Hey Ray,
I didn't use the adapter plate. I tapped into the existing oil plug sensor for the oil temp and I have to buy a fitting to use to plug in my pressure sensor onto the oil pump. I haven't hit the 1 year mark either! I would have liked to do more though.
Just walked out to my car sitting in the parking lot and it reads 135F, which would equal 57-58C. Is this what you guys are seeing?
I've already seen temperatures reading above 200F yesterday afternoon while driving on the freeway.
There's some info here that might interest you...
https://www.evolutionm.net/forums/sh...hlight=cooling
it's about road racing and keeping the car cool. It has some temperature info you can compare with.
antics22
Apr 20, 2009 11:23 AM
Daryl Nilsen
Aug 15, 2007 08:26 PM
