Dial-IN! Stock Turbo BEAST ready for 10's!
Ya im still on a hallman mbc,no im not on tephramod or anything
I dailly drive my e85 tuned car
the reason im on such wide wheels is for the stance look.
The wheels in low offset give it the wide look and trust me they look amazing.
I actually had these tires on my previous rims so that's y im using them, but i do want to upgrade to a 255 eventually
all that and still a MBC? someone needs a GM 3 port and ECU-controlled boost
are you running TephraMods? NLTS could help your time out.
edit: I really like the wheels, is that the special brilliant coating? and, are you really running 245 tires on a 9.5" wheel? I ran a 245/40 of the same tire on a 8" RPF1, and would have gone 255 if they were in stock... why have a 9.5" wheel and put on a tire made for a 8.5" one?
Gread Lakes Dragway ( http://www.greatlakesdragaway.com/ ) holds real street drags (RSD) once a month, its basically anything goes drag or street racing on the track, side bets etc. They turn the clocks off too so you're the only one that sees your time on the slip.
Great time for stock turbo I did similar times with an unported turbo, stock intake manifold 880cc injectors smaller cams and stock o2 housing on 110, Hopefully with that setup you should hit the high 10's.
