SST & hand brake?
Old Jul 3, 2009 | 12:12 PM
Boba's Avatar
SST & hand brake?
Can I use hand brake with SST?
Old Jul 3, 2009 | 10:18 PM
NZEvox's Avatar
Yep
Old Jul 5, 2009 | 02:13 PM
madcows's Avatar
Being able to use the e-brake on an AWD car is determined primarily by the type of center differential, rather than the gearbox. In the case of the EvoIX, X, and RalliArt, pulling on the handbrake signals the center diff computer to set the diff to fully open so you can lock up the rear wheels while still sending power to the front.
Old Jul 5, 2009 | 10:56 PM
gunzo's Avatar
I would be careful on how that is phrased ..
The ACD ATTEMPTS to open up the differential when you pull on the handbrakes .. but it does not really free up the diff totally ..
I've known of clowns that think that so and tries to run the Evo on a 2WD dynojet with the handbrakes pulled .. needless to say .. they ended up changing the entire ACD assembly ..
Old Jul 9, 2009 | 09:29 PM
madcows's Avatar
Good insight. I guess it's not surprising that there might always be at least a little friction. What is your take on doing handbrake-induced turns with the ACD? Too dangerous? I suppose race teams can afford to replace the ACD clutches after several races.
Old Jan 6, 2010 | 11:01 AM
userwave's Avatar
so to sum up is it recommended or not recommended to do handbrake turns with the SST/MR
lots of snow covered parking lots around here lately, can anyone safely confirm.
Old Jan 6, 2010 | 11:59 AM
Webman's Avatar
It's made to slip, but you just don't want to go overboard by trying to lock up your back wheels and turn the car into a FWD. But to occasionally lock up to drift or whatever, I'm sure the ACD is more than capable of handling this.
wrx_ua
Mitsubishi TC-SST Discussion
Feb 20, 2016 09:09 PM
moody91180
Oct 11, 2014 07:22 PM
Grape Juice
Nov 26, 2013 01:47 PM
mhershorn
Aug 29, 2013 06:15 PM
doclin
Driving Techniques
23
Jul 13, 2010 07:38 PM
Quick Reply: SST & hand brake?
