TheSin's TC-SST Project an SSP Production
Old Aug 13, 2009, 05:16 PM
  #91
JONralli09's Avatar
how many days with the car down?
Old Aug 13, 2009, 05:38 PM
  #92
TheSin's Avatar
I think it could be done in a good weekend, for me it's much longer cause I'm having things custom done and learning as I go once the howto is done it'll be pretty fast. So far I'm 6 days in but not even close to full days maybe 4 hours a day and I spent 2 in the wrong direction cause I was trying to do it without dropping the engine to start.
Old Aug 13, 2009, 08:37 PM
  #93
RotorGlow's Avatar
I'm pretty sure that the aluminum (right?) casing is made in china. It has so many air bubbles in it! Sure hope it's not under alot of stress because them air pockets will make it very weak. The tranny could have better cooling if those drain holes (I'm asuming) were properly cleaned up so the oil could flow better.
Yikes!
Old Aug 14, 2009, 06:37 AM
  #94
TheSin's Avatar
I totally agree with you!!
Old Aug 14, 2009, 08:38 AM
  #95
Mendo's Avatar
WOW just wow.
Great job man and huge props!
Old Aug 17, 2009, 08:29 AM
  #96
TheSin's Avatar
Okay well an other weekend by and the car is back together, I'm still waiting on the cooler to arrive should be on wed, but I got pics of the pan installed, so here we go
Attached Thumbnails TheSin's TC-SST Project an SSP Production-p8160025.jpg   TheSin's TC-SST Project an SSP Production-p8160026.jpg   TheSin's TC-SST Project an SSP Production-p8160027.jpg   TheSin's TC-SST Project an SSP Production-p8160028.jpg
Old Aug 17, 2009, 05:51 PM
  #97
snoar's Avatar
very nice!
Old Aug 19, 2009, 01:10 AM
  #98
alphawav's Avatar
looks SICK!!!! finally some good stuff for the SST. keep it up . whats next?
Old Aug 19, 2009, 09:16 AM
  #99
TheSin's Avatar
Okay guys here is the SSP front mount cooler w/fan and pump and the inline filter sorry for the crappy iPhone pics
Attached Thumbnails TheSin's TC-SST Project an SSP Production-img_0052.jpg   TheSin's TC-SST Project an SSP Production-img_0053.jpg   TheSin's TC-SST Project an SSP Production-img_0054.jpg   TheSin's TC-SST Project an SSP Production-img_0056.jpg   TheSin's TC-SST Project an SSP Production-img_0057.jpg
Old Aug 19, 2009, 11:34 AM
  #100
mrMTB's Avatar
TheSin, firstly- thanks for the excellent write up. It's nice of you to document the trail you are blazing.
Secondly, what's the scoop on the front-mount cooler? I only see the rear-mount one available on MAP's site.
Old Aug 19, 2009, 11:52 AM
  #101
ChrisCarey's Avatar
Weird I will have to get that up on the website ASAP, in the meantime you can always contact us for pricing or to place an order
Old Aug 19, 2009, 12:35 PM
  #102
TheSin's Avatar
it's from SSP, and it was just released so I might be the first installer of it and as such just might not be online yet. Contact SSP Kris for info on it or MAP direct.
Old Aug 19, 2009, 01:38 PM
  #103
Chebosto's Avatar
i didn't see it in the picts, but where the new sump pan goes, where does the factory suction tube go, if there is one? will it reach to the bottom of the new pan? is the pan completely full in the OEM such that there will be no sloshing of fluid around?
what did u use for new gasket? liquid-gasket?
Old Aug 19, 2009, 03:04 PM
  #104
TheSin's Avatar
The suction is along the bottom of the tranny and sticks out a bit in the front the pan is in the front so it'll be fine.
The pan is pretty much perfect it has the OEM reusable rubber gasket lines built in so I reused the OEM and it fit like a glove!
you can see the groove for it in the none anodized pics a few posts back.
Old Aug 19, 2009, 07:14 PM
  #105
robevo8's Avatar
cant wait till its all running!!!
Quick Reply: TheSin's TC-SST Project an SSP Production
