Compiled List of all SST Oil Coolers
This is a compiled list of SST Transmission coolers
AMS Performance Driver Side Mount Cooler
What's Included:
- One of the best oil coolers on the market
- Electric fan that easily wires into the factory fuse box
- Stainless steel brackets for long life and a seamless install
- All necessary hardware and wiring to install in the OEM location and to OEM lines
Retail: $519
ARC Cooler -- Need More Info and Picture
"Direct Replacement"
Blitz Cooler -- Need More Info and better Picture
"Complete kit with shields tandem"
GReddy Circuit Spec. SST Transmission Cooler Kit
Details:
This is a cooler that runs parallel with the factory cooler. It runs parallel to the ground, using under panel air for cooling.
What's Included:
- 160l/hr pump
- Lines
- Cooler
- LICP
Retail: $1650
HKS Cooler Front Mount Cooler
SST Oil Cooler Core Specs:
-200mm x 120mm x 32mm 9 row core
-Mounted in front of the radiator
What's included:
-SST Oil Pump
-Air Cooled Oil Cooler Core
-Misc. Hose
-Misc. Fitting
-Brackets
-Bolts and other Misc. Items
Other items needed but not included:
-SST Oil x 7L
-Wire (Able to work in temps exceeding 80 degrees Celsius) x 2m
-ON/OFF Switch x 1
-Relay (Approx. 200W Capability) x 1
-Fuse Holder (15A Capable)
-Terminals
Retail $1530
Road Race Engineering (RRE) -- Need more Info
Robi Spec Cooler -- Need More Info and Picture
SSP Performance Front Mount Cooler
What's included:
-High flow dual pass 6x16 oil cooler
-Single high flow 6" fan with shroud
-High flow 2.5 gpm oil pump
-6 AN high quality oil hose
-Complete wiring harness
-Heavy duty toggle switch
-Heavy duty fuse holder
-2 Banjo fittings
-2- 90 degree -6AN fittings
-2 -6AN straight fittings
-Assortment self tapping screws, and hardware
Retail: $850
I know there were some in production by HKS and Blitz, if you can add them to the threads I'll post them in this first post so everyone can see the compiled list.
What's Included:
Retail: $519
Details:
What's Included:
- 160l/hr pump
- Lines
- Cooler
- LICP
Retail: $1650
What's included:
-SST Oil Pump
-Misc. Hose
-Misc. Fitting
-Brackets
-SST Oil x 7L
-ON/OFF Switch x 1
-Terminals
Retail $1530
What's included:
-2 Banjo fittings
Retail: $850
ok the BLITZ one is a complete kit with shields tandem
the HKS unit comes with a pump setup and a solinoid tandem
ARC about to release one as a direct replacment
Gunzo's set up and the SSP setup are nearly identical, except that SSP mounts theirs on the right, which means it obviously possible to run two front mounts. Gunzo, How much trimming was required on the facia for your cooler to clear everything? I notice you spaced yours in front of the crash bar slightly, presumably to clear the a/c line?
Blitz Cooler require you to cut the front bumper beam and some other stuff .. its really weird ..
what about these oil coolers to make some yourself http://www.cxracing.com/mm5/merchant...gory_Code=RDOC i know its all Chinese and seems very sketchy but hey some of their stuff is actually good
0 trimming or cutting .. and it doesn't block the intake snorkel .. I'm quite sure the SSP unit got to cut something .. and the fan is really not needed in front unless you're not moving fast enough .. identical is the way to put it hehe .. should have never posted up the pics .. Anyways .. I got the idea from HKS .. so in a way I used HKS's idea too
