08 MR SST Wont shift out of Park! Please help!!
Old Sep 16, 2010, 09:14 AM
NOMIEZVR4's Avatar
2008 EVO X MR, I changed the battery with a redtop optima. Now the car is stuck in Park and the gear selector wont move. One thing to note, the gear selector light is not illuminating, usually it glows orange to show the gear that the car is in, however I've got no light. I've run through the wiring diagram, checking possible fuses with no success. Please help..
Old Sep 16, 2010, 09:35 AM
turpdogg's Avatar
Push the brake pedal. LOL....
Old Sep 16, 2010, 09:43 AM
robevo8's Avatar
i would go back and check all the fuses, not just a couple. some times there are ones that due multiple circuits but named things you wouldnt think have anything to do with what your looking for... for example when i was a car audio installer people would come in with thing not working in their car , they my have checked some fuses, but ill go under the hood for example and find one or two more they didnt check.
seeing as you put a new battery, there is that chance something popped a fuse
any who, even if its not that, doesnt hurt to try... goodluck!
Mendo's Avatar
Sure the battery is plugged in properly?? Also make sure the brake pedal is fully pressed
Old Sep 16, 2010, 09:49 AM
EvoM Community Team
migs647's Avatar
Are you talking about the light on the actual shift panel or the # on the LCD screen in the gauge cluster?
If you're talking about the shift panel, you definitely blew a fuse. Make sure you check the kick panel fuses as well.
Old Sep 16, 2010, 01:49 PM
NOMIEZVR4's Avatar
I went through ALL the fuses, I checked all of them with a test light. I did not find any blown fuses under the hood or under the dash, that is whats confusing me. I disconnected the shifter cable and the trans itself goes into gear, so its not a mechanical issue. Its something electrical..
The car starts without any issues, its just not going into gear, also the switch to put in sport or super sport mode isn't functional either.
I just swapped a built shortblock into the car, so I am somewhat mechanically inclined..
Old Sep 16, 2010, 01:50 PM
NOMIEZVR4's Avatar
The shift panel, not on the cluster. You are correct.
Old Sep 16, 2010, 01:51 PM
EvoM Community Team
migs647's Avatar
No codes I take it?
Old Sep 16, 2010, 02:03 PM
NOMIEZVR4's Avatar
for the ABS its got a code. But it was on prior to the problem.
Old Sep 17, 2010, 08:15 AM
lousEVOxmr's Avatar
ummm.... might sound stupid , get a friend to rock the car back in forth with out the parking brake on ... lo l and try to change the position of the liver
Old Sep 17, 2010, 03:25 PM
Captainslacker's Avatar
There's usually a switch on the brake arm. That's what releases the parking brake. Normally you'll hear the disengagement.
Old Feb 15, 2012, 01:51 PM
Mako_7's Avatar
Thumbs down
you probably drive on here more than you drive your car
Old Feb 21, 2012, 12:50 PM
eg6motion's Avatar
you just replied to a post that's 2 years old.
Old Oct 25, 2014, 02:44 PM
jackal5555's Avatar
I had the same issue. I had a bad brake light switch. Replaced it and fixed the problem. advance auto had it. $15. I love easy fixes.
Old Aug 23, 2020, 10:01 PM
Tt643's Avatar
To the op what was the fault ,my cars the same.
thanks
Quick Reply: 08 MR SST Wont shift out of Park! Please help!!
