TC-SST Leaking?
No clue, but mine is leaking as well. The dealer told me the tranny was leaking and they fixed the problem....
Did my oil change the other week and I found oil on my plastic guard. They really need to get on this.
Mine was a cracked trans filter housing too.
It took them over 2 weeks to finally fix it after they had to send someone from corporate to look at my car for some reason, then the parts didn't come in on time, then the molds were wrong.
I got a brand new 2011 Mustang V6 with 100 miles on it to drive while they were fixing it though. Definitely like the RA better.
I also have a popping noise behind my rear fender on the driver side and I found other guys on here having the same problem and found that its probably a missing weld.
my sst filter was leaking. replaced under warranty no hassle..discovered when my bumper was attempted to be stolen
i also have the front driver side noise..anyone that can post a list ill take to my dealership and make them figure out my problem and post back.
good question lol..there is 1 black gsr evo in town...a orange ralliart and a passer by evo with normal grey...none of which would even match my car..musta been a GTS driver wanting to upgrade haha. Sad people do it..even sadder when they dont complete the job!
tranny leaking on my 2010 with less than 8k and not hard driven... they put everything new but the job took them like 2 1/2 weeks to complete the job...asking dealership because apparently is a pretty common fail in 2010's...
What you guys think about this failure??wud likely affect the car again??
thanks in advance...
it appears to be a specific line of 2010 models from what I've gathered but no hard evidence to confirm this. My 08 with 33000 miles appears to be ok and I've also already have to trans filter/fluid replaced already.
My 2010 RA has just over 6100 miles. It is a slow leak from what I can tell and the plastic undertray catches it. So it had to collect for a little while before I found the drop in the Garage. From the pictures I have seen it looks like the filter housing is made of plastic. Anyone actually put hands on this piece?
Has anyone compared an 08 to 10 version? Did they really change them? Seems something silly to change if they were working fine in 08. Perhaps they changed the manufacturer during that time and someone dropped the ball during that time.
My leak was *not* from the housing... 2010 RA
