Best tranny cooler for the MR?
While I've not seen the MAP option, I think both the AMS and SSP options are quite nice. Perhaps the SSP cooler, with its second heat exchanger and dedicated pump, will give you extended thermal control over the AMS, but until you get to a very serious level at the track, I think the AMS would be more-than-enough to allow you to run uninterrupted 20-25 minute sessions all day long.
Full disclosure: I own the SSP
EvoM Community Team
See the sticky in this forum.
There are plenty of aftermarket coolers. I personally like the series coolers like HKS, Blitz, SSP more so than the fan mounted replacement coolers (AMS). I was going to go the Blitz route for my track car, but I'm going to build up an VIII track car instead.
https://www.evolutionm.net/forums/mi...l-coolers.html
Get the SSP Front Mount Transmission Cooler Kit and be done with it!
I am using OEM fluid, looong debate in the forums, I shall not take sides. Mitisu does not approve of any of the aftermarket fluids so it could be grounds for (or an excuse) denying warrantee work. I did get up to .2 sec faster 60’ times at the drag strip and and firmer feeling shifts with aftermarket SST fluid (probably due to a higher viscosity index) but see little else to recommend it. I had an electronic failure on my SST box whilst I happened to be using an aftermarket SST fluid so I now err on the side of safety and only use oem SSTF-1
2010 MR-T (SST)
Stock clutch packs
OEM DiaQueen SST fluid
SSP trans Deep Sump
SSP Front mount trans cooler
OEM intake w/dropin
CBRD BBX full Turbo
AMS DP
RRE Rally test pipe
MXP II CBE
DP 1000 injectors
BlaqOps single pump
WORKS tune using OP (cleaned up by Bryan)
Green relay (yeah that’s it, it MUST be a faulty fuel pump relay!)
2010 MR-T (SST)
Stock clutch packs
SSP trans Deep Sump
OEM intake w/dropin
CBRD BBX full Turbo
AMS DP
RRE Rally test pipe
MXP II CBE
DP 1000 injectors
BlaqOps single pump
Do you offer military discounts.. and all... i am really intrested in your tranny cooler.. as i am on the brink of 400hp!
Please let me know of any price help you can do.. balling on a budget... Military budget
i know on the AMS you can't use an after market LICP... so thats why makes me say no to AMS...
i want the tranny cooler... before i get my cams installed.. b/c i am really close to 400 and after my cam install i don;t it to break... can;t afford a 7500 tranny
