Tuned SST issues
Tuned SST issues
I have just had installed the SSP 600 kit to my SST evo X- UK model.
Running kelford cams
AMS intercooler
FP Red
1000cc injectors
Fully forged engine etc etc
Ecutek remap
We are having issues with driveability- if you are slowly accelerating in normal or sport modes. auto or manual, the revs rise in 500 rpm increments.
If you are cruising along at a set speed then the revs rise and fall 400-500 rpm, but speed stays constant. This is very annoying, its almost as if the clutches are clamping then releasing then clamping.
Supersport mode is fine, but the changes are too harsh and it jerks badly at lower rpm changes. Full WOT gearchange in SS is ok.
The gearbox has been stripped and rebuilt using new clutch packs so we are 100% gearbox mechanicals are fine.
Any help is greatly appreciated.
Thanks in advance
AMS intercooler
FP Red
1000cc injectors
Ecutek remap
Thanks in advance
Sounds like the SST realted tables need to be tweaked... torque request etc etc. It's been almost 2 years since I looked at an updated set of EcuTek maps.... Back then they did not have the required tables defined. Not sure about now. Your tuner needs to contact EcuTek about getting access to the SST related tables.
The other option is to pull the current rom with an openport 2.0 cable and see if you can work with Bryan (RazorLab) or One of the other tuners that has access to the SST tables. In fact, this may be your only option.
Fireescape
Jul 4, 2016 11:18 PM
curamrdan
Apr 10, 2013 03:46 PM
l2r99gst
Aug 28, 2011 03:39 AM
St1g
Mitsubishi TC-SST Discussion
16
Feb 15, 2010 09:01 AM
