Evo MR SST - 11.0@127mph
Old Sep 23, 2011, 09:30 AM
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
Originally Posted by tephra
I would LOVE to see the slip rates and clutch temps from a 1/4 pass..
I know you are probably asking about this car in particular but from what I have seen on average from "going through the gears" on the MR's I've tuned is that you don't usually see much slip after the initial spool up and torque hit. When it's at full boil, each WOT clutch change doesn't show much slip, if at all.
The clutch temps on the other hand do go up on every up gear change. Usually ramp up hard on each initial clamp change, then slowly drop over the duration of the pull in that gear.
Old Sep 23, 2011, 11:56 PM
kijima's Avatar
Tephra, there is a certain Evo X SST owner that is happy to take his car to the drags and log it at the same time.
Just sayin...
Old Sep 26, 2011, 06:00 AM
mrboost05's Avatar
Originally Posted by razorlab
Why on earth does that car run four fuel pumps???
what he said ?
Old Sep 26, 2011, 06:14 AM
masafina's Avatar
Originally Posted by Hiboost
Good question, we need to find out what setup worked for them, although I can hear some slight slippage going on in the lower gears.
The bouncing the rev limiter thing from 1st -> 2nd could be cured with some TPS table tuning as well.
EDIT: From an SSP post in Facebook:
Specs on Car:
2008 Evo X MR.
2.5ltr Bottom End
Upgraded Factory cylinder head Ported,
Tomei Cams, upgraded valves, valve springs etc.
E85 twin intank walbro’s feeding a custom surge tank and then 2 further walbros feeding 2000cc ID injectors.
FP Black
Tubular exhaust manifold,
Hyperflow Intercooler with custom aluminium pipework.
Factory intake manifold ported to match cylinder head.
Ecutek software tuned by Sean Day at S&J Automotive.
SSP 500hp clutch pack,
SSP Deep Sump,
SSP rear mounted Transcooler,
BC Coilovers,
Whitline swaybars and various other suspension mods.
Car has been lightened by removal of full interior. A/C system, front and rear crash bars etc.
my respect to that car, but is to much $$$$ on parts to do that time
Old Oct 12, 2011, 07:51 AM
niteflyer's Avatar
damn!
Old Nov 1, 2011, 06:44 PM
noenoe_pro's Avatar
This is FAST!!!!! man I wanna see 600Whp MR soon..
vaqusis
261
Dec 1, 2022 01:46 PM
Fuego
Mitsubishi TC-SST Discussion
Oct 19, 2016 08:40 AM
emperor496
Jun 19, 2015 03:34 AM
HxllxMan
Feb 7, 2010 01:14 PM
LVSBB6
Nov 30, 2008 09:12 PM
Quick Reply: Evo MR SST - 11.0@127mph
