My launch control crapped out on me. Cobb AP and basic mods
The other night, I wanted to show two friends the launch control in my '11 MR. I get to a flat, open stretch of road and do what I've done numerous times in the past without problems. I turn off AYC Brake fully (hold ASC button for a few seconds until beep and release), put trans into S-Sport mode, mash brake and gas simultaneously...
The engine revved to 5,500 rpm (like normal). I held it for 2 seconds then released the brake. It felt like the car rolled forward slightly. RPMs maxed out and I got a Transmission Overheating message and I went nowhere. The trans went into a neutral state while still in drive and I had to shift to park before trying to drive again.
I thought ok maybe it's nothing and I tried again. Same exact thing happened the second time. Instead of launching it, I just slowly let off the brake and then mashed the gas WOT and no problems. Clutches held the whole way through 5th gear without slippage.
My last successful launch using launch control was when I only had a turboback exhaust and a stage 1 Cobb tune. NOTHING ELSE. Stock intake and everything. This time, I have a Cobb SF intake and a stage 2 SF tune. Could it be that my engine is making enough power now to make the tranny throw an error code when a launch is attempted? Maybe that slight increase in HP from the intake and tune is making launch control **** the bed?
I'm not sure if it's because the tranny is hot. I've launched it successfully when it was hotter. Plus I tried it again the next day after letting the engine get to normal temp. No good. I even loaded the stage 1 map that I had before the intake and that didn't work either. Maybe the torque limits in the SST tables need to be increased?
I believe it has to be warmed up but not 2 hot. I thought it didn’t work on mine until I drove it for about 20mins then tried it. Previous day i had driven 3 1/2 hrs on the freeway and it didn’t work when got to my destination
It's not always the current temp the TCU is flagging the slow down message for, it also has a predictive overheating check so that if the clutch temps are rising too rapidly it also shuts down the party. This happened once when my car was stock and I did a brake boost launch instead of the stationary limiter by accident, it really didn't like that for more than 5 seconds.
On the stage 2 map I've had more frequent "transmission overheating" messages. Autocross once, frequently when doing hot laps at drag racing. I think it's a combination of less-than-perfect SST tables and the fact that I actually probably am warming things up a bit much. It's definitely worse on stage 2 than on stage 1 of the canned tunes though. Haven't run the beta stage 2's yet.
alfonso_meneses
Oct 18, 2016 11:19 PM
Harumsevo
Jul 30, 2013 05:19 PM
David Buschur
114
Feb 4, 2013 09:02 AM
BeyondLimitsEvo
Cobb AccessPORT
Jul 20, 2012 08:07 AM
