Wont engage reverse and unable to pull fault code
Well, after saving up to get my gearbox clutch packs and seals replaced and finally having the car back on the road for a few months my SST has now decided it doesn't want to engage reverse
I had already decided I was going to sell it because I cant afford to run it but now its broken again so cant get rid!
Anyway, enough of the sob story! The car wont engage reverse at all, I can hear a repeated 'clamping' noise from the box and the car sorts of rocks forwards a little bit whilst the reverse light blinks on the dash. It also sometimes skips 1st and goes straight to second. The lack of reverse is the real killer though. Have tried numerous times to get it to engage, though plenty of ignition cycles, always with my foot firmly on the brake.
I have tried doing an SST teach-in but the procedure failed at the Shift Fork teach-in stage. The dash gives me a service required message but I cannot seem to pull the code using EvoScan, with Evo X SST selected. Is EvoScan capable of pulling gearbox codes?
Does anyone have any ideas on what I could try? Both to fix it and also to try and pull a fault code from it. Any help would be great
Sorry for the long thread bump, but this just happened to my car. After driving to work this morning my car wouldn't go into reverse! The R light was flashing and it wouldn't go into reverse. Did you ever resolve this issue?
Most of the time this is clutch related, but not always. It will set a code if it won't go into gear. You may not be able to read it depending on what reader you are using. If you lift off the brake when putting it into reverse, it may help coax it in by unloading the transmission.
ES_02
Lancer Tranny/Drivetrain Tech
36
Feb 13, 2008 09:07 PM
JohnnyBoy427
Jul 13, 2007 05:38 AM
