Replacing trans in 09 RA with 15 MR SST
So I am about to have my local shop swap my ailing SST in my 09 RA with a very low mileage unit from a 15 MR. I can;t find a concrete answer what needs to be done flash wise to the ECU or TCU to make everything work happily.
My first goal is obviously to make the car drive properly again, but obviously I still want to take advantage of the S-Sport mode AND launch control programming in the 15 MR tranny.
Any advice? Dropping the car off today!
Did you check to make sure that the wiring will match up? They did a wiring harness change in 2011, so anything that runs thru the CAN Bus system and the ETACS sys will have a different pin out.
Well, too late for that! In reading through all the information about flashing the TCU via TACTRIX, it seems like there are no issues using that method to flash if needed. Also, I have been told the TCU (metronic?) itself is plug and play through all years. As the wiring harness connects directly to that I can;t see where the difference would be.
I told the shop to verify the wiring before proceeding just to be safe. I'm also going to see if I can find a service manual online to look at. Im new to the car, so haven't had to find any of this yet!
Well I wanted to post an update in case anybody ever needs the information. Nothing to worry about!
To recap, Car is a 2009 Ralliart, and we swapped in a 2015 MR transmission. Plug and play! No need for any re flashing, teach-in or anything else. Wiring was all identical. Car drives completely different now, and that's a good thing. Car now also has S-Sport mode. Can not confirm launch control yet, as I am going to take it easy on things for a bit, but I have no reason to suspect it is not there as well!
Congrats on the new, better trans!
You might want to also use the MR specific SST tables in the engine ROM to make sure everything is working well together. There are a bunch of torque tables and such in the ECU that are much different for MR compared to RA.
The RA has come a long way since i owned one
Hence my post about the MUT3 tool.
z
e
R
e
p
Yes you now have LC too as that and S-Sport is contained in the TCU attached to the transmission.
LVSBB6
For Sale - Part Outs
Mar 15, 2015 05:34 PM
moody91180
Mitsubishi TC-SST Discussion
Oct 11, 2014 06:22 PM
SSP Jeremy
EvoX 'For Sale' Engine Internals and Drivetrain
35
Aug 13, 2013 08:42 AM
SmurfZilla
13
Oct 6, 2012 01:29 PM
