Teach-in and other questions
Hi, hope to have an answer here.
2008 EVO X MR, SST software just upgraded with evoscan SST mod.
I need to do a complete teach-in because of new upgraded clutches (odd gears doesn't engage).
Both evoscan and passthru (and also AUTEL) gives me abnormal end from the plausibility check, evoscan with error 01 10, passthru 0000.
I have been told to check the brake switch and the idle, and both are ok.
Ideas?
Ideas?
the 08 didn't ahve the TCU software to do a teach-in. Did you update to the B151 file before teach in? Also what is your idle RPM set to?
Yes, I upgraded with the B151 SST mod from evoscan. Initially the teach-in procedures doesn't start at all, now with the new TCU software it starts but gives me abnormal end very time.
Gearbox is in P, brake depressed and parking brake ON.
Stock Idle, around 800 rpm, a little lower.
The data list at idle, before the attempt to do a teach-in, in bold suspect values :
Engine torque control source: Idle control
Break SW: ON
Lever position: P
Current Gear: N
Target gear: N
Parking Brake: ON
Vehicle speed: 0
ABS/ASC operation flag: OFF
ABS/ASC status: Normal mode
Paddle SW (up): OFF
Paddle SW (down): OFF
Drive mode (SW input): DEFAULT
ASC gear hold request: No request
AYC gear hold request: OFF
FL speed sensor: 0
FR speed sensor: 0
RL speed sensor: 0
RR speed sensor: 0
Cold shift request: OFF
Idle up request flag: OFF
Torque limit by spark retard: OFF
Torque limit by fuel cutoff: OFF
Torque increase request flag: OFF
Torque reduction request flagg: OFF
Torque limit by throttle closing: OFF
T/M temperature sensor: 46*C
T/M temperature warning: OFF
Drive mode SW: Normal
Gear change mode: Auto
Meter displayed Gear: P
T/M fail flag: OFF
ECU operation status: Extended session
Current gear (internal data): N
Pre select gear (internal data): N
Gear odd (internal data): 1st
Gear even(internal data): 2nd
Clutch (odd temperature): 45.75*C
Clutch (even temperature): 45.5*C
Clutch (odd) slip speed: 757rpm
Clutch (even) slip speed: 757rpm
Coding Counter: 1
Battery Voltage: 14.02
Clutch(odd) pressure sensor: 356 mbar
Clutch(even) pressure sensor: 390 mbar
Shift fork position sensor 1: 8.98mm
Shift fork position sensor 2: -0.47mm
Shift fork position sensor 3: -0.3mm
Shift fork position sensor 4: -10.23mm
Clutch shift pressure solenoid 1: 333 mA
Clutch shift pressure solenoid 2: 152 mA
Clutch cooling solenoid: 713mA
Line pressure solenoid: 1304mA
Input shaft (odd) speed: 0
Input shaft (even) speed: 0
Dumper speed sensor: 733 rpm
ECU temperature (internal data): 45.75*C
APS: 0.0%
Break SW: ON
Lever position: P
Current Gear: N
Target gear: N
Parking Brake: ON
Vehicle speed: 0
Paddle SW (up): OFF
FL speed sensor: 0
FR speed sensor: 0
RL speed sensor: 0
RR speed sensor: 0
T/M fail flag: OFF
Coding Counter: 1
APS: 0.0%
Re-reading your first post. You may need to reach out to Tephra to have him update your rom. His roms all default to "Clutch Switch" sensor, you need to have it set to "brake switch" sensor as you do not have a clutch pedal, this is often why Launch Control does not work with SST evo's on Tephra as well.
As you can see in the data list from SST TCU the brake switch is correctly recognized.
If I remember correctly I already modified the clutch to brake switch in the XMODV3
