rally raid time!!
rally raid time!!
I'm thinking a retro interpretation of the pajero evo, weeeeeeee!!
rally raid time!
So, 2.4 liter 4g64T twin cam engine looking to make between 300-350hp when done.
The trucks curb weight is 3260lbs so it should scoot along pretty well, looking for a 0 to 60 time in the 4.5 second range roughly.
The drivetrain is going to stay 2WD/4WD selectable as the KM145 trans has proven itself reliable up to 400hp, maybe in the future I will upgrade the trans to a SS2 out of a newer 5speed montero to give me the option of 2WD/AWD/4WD or maybe not....
The laboratory
Doing a complete overhaul of everything to get it abuse worthy. There's something like 10+ yrs of deferred maintenance lurking under this thing and a tired trans that howels like a WRC gearbox. haha, poor little truck's had the **** beat out of it off road for many years.
Found a super rare factory mechanical LSD at pick n pull!
LSD trip FTW! haha
packages with car stuff yea!!
Poppin in the bouncy bits!
aaand this is why you don't get in a hurry.... bent oil control ring FTMFL haha.
Getting it ready 4 paint
Oh boy, mail santa brought me a box!
It's baaack...
and better than evar! (I know, not a big deal with your fancy newfandangled evo ECUs that are already flashable <_< )
Next comes this
It's been slow going lately, were in the middle of moving the shop to a bigger building so .....
Artsy piston shot!!!
Cleaned the head, no more dirty thoughts....
Test fit
Getting the factory thermostat location cleaned up for a block off plate
Measuring to drill for 2nd coolant hole at the rear of the head.
Treasure located, time to dig
Start with a little bit, there's not a ton of room for error. EGR passage on one side and valve dome wall on the other
and its gotta line up with the passage on the block
First small hole drilled
drilling second larger hole after confirming correct location
Done, yay!
Lines up nicely
Notice front of RWD head gasket has no coolant passage holes
The maddness behind this is, because I'm moving the thermostat housing to the front of the head I need to improve coolant flow through the rear so coolant doesnt sit there stagnant and steam. I accomplish this by closing off the ports in the front and opening them up in the rear of the head therby forcing the coolant to flow up through the back of the head from the block and to the front exiting via the newly located thermostat housing.
Moving into the thermostat cave with the boroscope, scary!!
Shavings from drilling are on the floor of the coolant passage which is actually the celing as the head is upsidedown right now,
the big circular structure ahead with the casting line in it is the outer jacket of cylinder #4's valve dome, no monsters yet.
Were on the inside of the coolant passage in the head looking through the hole I just drilled,
yes that is my eye ball pressed against the outside bottom of the head looking back inside, haha found the monster
Helping the epoxy paint on the moddified headlight bezels to dry
Stir in some moddified BMW 5 series projector buckets
With a nice press in fit.
Add some clean epoxy adhesive action
compared to old sealed beam
I can haz projectors!! and retain factory aiming ability. I might give 'em halos, depends on how rice I feel later.
rarrr!
New injectors yaay!
Mitsubishi loves california so much that they included a model of it with every 4G! haha
rally raid time!
The laboratory
LSD trip FTW! haha
It's baaack...
Next comes this
Test fit
Done, yay!
Lines up nicely
rarrr!
New injectors yaay!
It looks like it's trying to crawl back up in there...
So it was obliged...
decided to stud it just because
as it sits now
Progress on the rally truck today!
Now it's on to the 10% of the stuff that takes 90% of the time....
The engine assembly sits behind the front axle. :good: This is a good thing.
Craft time! gotta modify the pan to clear the front diff
pieces mocked up gotta weld...
All kinds of projects goin on here!
too late, will finish pan tomorrow.
as it sits now
So moved to the rear suspension to give this thing some better manners.
The factory setup is pretty basic, were gonna add some drag links, sway bar to keep the rear under control.
Throw in some fire!
line up some mount points on the axle and frame rail do a little welding.
and viola! drag links
The sway bar will come later...
There's also this little problem to get on.
peak-a-boo!
Throw in some fire!
peak-a-boo!
laksman91
09+ Ralliart Show and Shine
38
Apr 24, 2013 04:18 PM
AFI Turbo
AFI Turbo – Phoenix, AZ
14
Aug 8, 2011 09:12 AM
