Do Evo intercooler pipes fit an Airtrek?
As the title suggest, does anyone know if I can use Evo7/8 intercooler pipes to front mount an intercooler?
Thanks in advance.
Thanks in advance.
Good to know, Havent seen this thread until I did an "Airtrek" search.
Are you just adding the FMIC or you changing all go slow parts on the Airtrek to EVO8 or better..........ie. will you be retuning?
Would love some pics to see you progress too, as Im planning to swap to EVO8 spec setup
Looking to add an intercooler. Evo kits will fit with an Evo 4-8 turbo (minor mod) but need a custom turbo-to-intercooler pipe to fit the original turbo.
I'm thinking the best idea is to buy a high mileage Airtrek and completely swapping the g/box and engine for a low mileage Evo 8 setup with re-flash.
Yeah, Im swapping over to EVO8 spec, but keeping the auto tranny.........
I wanted to see pics of the FMIC behind the stock ATR bumper.
How does it fit size-wise and does it get anough air flow to function properly?
We just finished tuning completely stock airtrek- no mods at all but ecu fine tuning. 6 sek 0 to 100 km/h and 15 sek for quarter mile on stock td04 turbo, 1.35 bar boost, 91 gasoline. After that we installed hks 264 cams - 5.6 sek 0-100 km/h and 14 sek for quarter.
There is a bolt-on kit made by Greddy for Airtrek but it is expensive. Evo pipes will fit with slight mods but only the throttle to cooler side since the layouts of td04 and td05 are opposite to each over with regard to turbine outlet location. td05 oulet is located downside whilst td04 outlet is located upside. Normally we buy universal piping on ebay and weld the setup we need - 2 inch turbo to intercooler and 2.5 inch intercooler to throttle. Intercooler size should not be too big ( less then evo's one) if you are planning to run the stock turbo ( to avoid increasing in turbo lag).
There is upgrated stock turbo (td04-19t instead of stock td04-15t) being sold on ebay which is capable of delivering up to 350 hp. We are aiming to run 5.1-5.2 ( 13.5 sek for quarter) with that turbo.
-Shane
My setup is in the next thread but i'm running Garrett gtx3071r.
