Mitsubishi Outlander 2.0 Turbo ECU pinout?
Hi!
I have the Dimsport New Genius and TACTRIX Openport 2.0 , want to read and write a new software into a Mitsu Outlander 2006 Turbo 200hp 4G63, but my reflash connector isnt correct, looks diffrent in car compared to the cables i have...so if anyone know the pinout of the smaller white socket behind the OBD2 socket it would help me alot
OR if anyone have the pinout of the ECU of this veichle.
Thanx!
// Jonas
Thanx!
// Jonas
Hi mate.
I live in Norway and have tuned my outlander 2006 turbo alot with tactrix obd2 box and the evoscan outlander software. But now I upgrading to stand alone megasquirt MS3X
If you like too you can buy my evoscan code dongle that you need too acsess the ecu software from evoscan.
It is just too make a wire from the tactrix jack cabel too one of the wires on the white connector in the car. need to check my car witch cabel it was again.
Regards
Frode
Regards
Frode
Hi mate.
Regards
Frode
Regards
Frode
It connects too the green wire on the white connector.
hope you have moore than just the jack kabel, you need one of the other adapters and put a wire from one to the other.
still think you need the MMC software, I tried everything I found online but needed to byu the software from evoscan to open the hex file.then used ecuflash to make changes in the software.
took a pic but takes time too upload to my photobucket
hello , could anyone confirm this?
i have an openport cable 1.3 , and the white reflash connector is different in the outlander , it wont fit , it has two wires one green/yellow and one purple , which one should i splice and connect to the openport cable?
frode said the green one , vision79 did that work for you?
my outlander has an evo 8 ecu and evo 8 motor , which ecu pin corresponds to the white/reflash connector in an evo 8 ecu , so i can trace it back to the ecu if my connector is wrong?
thanx
thanx
thanxAttachment 316763
edpzwf
Lancer Engine Management / Tuning Forums
Apr 14, 2023 03:42 AM
somedood451
Mar 1, 2015 08:25 PM
