MitsubishiParts.NET | Last Minute Mark Down
I just noticed I seem to be missing a cover on the rear wiper arm of my Evo 9. Atleast I think there was a cover. I can see the nut that attaches the wiper arm to the rear of the car. Is there something that should be covering the nut? If so can you send me the part so I can put in an order along with some other stuff I need. NUT COVER MR538218
One more questions. Is the Evo IX Turbo Outlet Pipe Gasket a 3" (Part#MR281085). YES, THIS IS THE 2 BOLT GASKET
Also, do you have the black plastic frame that goes around the speedometer right above the steering column? The previous owner must have mounted a boost gauge there as it have two small holes right above the steering column.
Im not quote sure what you are wanting here. The image has me confused because of the angle. If its the black bit by the cluster order MR506452 , but if its the upper column cover you need MR633538
Saw that!
I actually ordered MR633538 Cover,steering Co, last night as mine is not clasping closed all the way so I'll just add the other one and hopefully they can be shipped together. Thanks for providing the product number. If I add it will I be charged shipping since it's less than $50. The order I put in last night was over $250. Can you add this (MR506452 Bezel,combination) to that order?
Order Number: ELM9-340484
Okay I called and they said to put in another order and it will be combined for the discount and free shipping.
It's Order Number ELM9-340511
