Switch GSR (non-aero) front undertray to MR undertray possible?
Russell
If I understand correctly, the Evo X MR undertray has some air guides that the Evo X GSR does not, correct? Also, does the Evo X MR have the zero lift kit like the Evo 8/9 MR's did?
So, can the Evo X MR undertray be swapped with the Evo X GSR undertray or just the sections with the air guides?
Thanks!
Thanks!
Russell
If I understand correctly, the MR undertray has some air guides that the GSR does not, correct? Also, does it also have the little flap like the Evo 8/9 MR's did?
So, can the GSR undertray be swapped with the MR undertray or just the sections with the air guides?
Thanks!
Thanks!
Zero Lift Kit
Brake Air Guides
Interesting - I read a PDF about there being 2 optional parts on Evo X that improves handling - 1 was the rear wing extension (which you sell painted, correct?) and the other was air guides, not for brakes, but for undertray...
Send me your email ID and I can send you the PDF, Russell. It has the air guides pictured. I need to crawl under Evo and see if it has the air guides, but I figured I did not since I was a GSR
i was wondering the same thing.
http://www.mitsubishi-motors.com/cor...ew/e/2008.html
under the "aerodynamics for lancer evolution x"
the airguides supposedly increase the negative pressure zone underneath the front of the car to help with anti lift
UnionPerformance
Vendor Classifieds
May 20, 2013 03:06 PM
kimma
Jan 30, 2011 02:04 PM
