Shocks For Autocross
I'm currently planning on attempting to campaign a fully prepped AS Evo next year (my wallet isn't big enough to play any higher), but the only option I have found in all my research for AS legal struts are the Ralliart Sport Suspension package. Unfortunatly, I have not been able to get any detailed info regarding the shock itself in spite of constant inquiries. Still trying though.
If anyone finds anything else, please let me know.
Devin
Devin
Originally Posted by Slowride
then add $700 a corner (x4) for the conversion.
It's cheaper to buy the Ohlins R&T and be done with it.
But if you really really want to run AS, these are the struts for you.
Koni also makes some really nice custom double adjustable versions based off the Evo factory KYB struts/ shocks. They are A-Stock legal with a price of $2200-2400.
Dave
Devin
Devin
In STU, I ran 1 set at $700 the entire season and then purchased a shaved set for Nationals. I'll use the second set for half of next season. Just an FYI and good luck.
Dave
Originally Posted by Silencer
If AS is your thing, then expect to go through R tires prematurely. I went through 3 1/2 sets in one summer (not including Nationals) and at $800-900 a set including mounting/balancing, it's not cheap. You will cord the outside edges because of the Evo's camber limited front suspension.
Dave
Dave
When I was running the Hoosier S03 in G-Stock on a CRX, the tires were done after 24 runs, and not worth taking to a big event (divisional or national) after 16 runs.
Comes out to about $28 per run for a stock class car. Crazy.. yes, but the close competition of the stock classes causes you to run for every advantage you can get.
Jon K
www.seat-time.com
Jon K
www.seat-time.com
Jon K
www.seat-time.com
Jon K
www.seat-time.com
Dave
Not so much. I had a set of shaved RA-1s last me a half year of racing 2 times a month. They do cord the outside edges prematurely, but that's where flipping a tire on it's rim comes into play. I plan on using RA-1s for all local events, and the set of 710's for all divisional/tour events.
Perhaps, Silencer, you were just overdriving the crap out of the tires. Anyway, I have already been running the Evo for half a year now on R-comps, I was just getting ready to step it up for next season.
Thanks for the link to the rebuilt MR Bilsteins, btw. That seems a little out of my cash league though when you factor in the initial cost of actually buying the Bilsteins.
If anyone has anymore, please let me know.
Devin
Devin
Devin
Devin
Let us know how you do.
Dave
Originally Posted by chronohunter
AFAIK you can't run the Ohlins with stock struts, you have to go with the ultra-high dollar Koni inserts They cost more than the Ohlins and you of course are limited to stock springs so they don't handle or ride as well as the Ohlins I recommend going up a class! Your car and wallet will be happier...
The rules for stock don't say that you have to use the stock strut assemblies. There's a guy in Cali that can get you an A Stock legal JRZ setup.
Devin
Devin
https://www.evolutionm.net/forums/sh...&highlight=jrz
Threaded struts = no no. That's what makes it so hard to find some.
Unless later in the thread they specify that they are going to make a fixed perch version that I did not see.
Devin
Devin
Devin
Devin
Section 13.5 Shosk Absorbers
of the 2005 rules:
3. Adjustable spring perches are allowed, but the spring loadbearing
surface must be in the same location relative to the
shock mounting points as on the standard part. Shims may be
used to achieve compliance.
A guy in my region silconed his perches in place to show his competitors that the ride height has not changed. He's been to Topeka the last two years in an S2K. No protests.
