Road Course/Auto x Guys. A Re-circ bov w/o flutter is?
When running stock, it was fine. Then my stock plastic started leaking, then the nipple broke off of the top, so i went with the older forge unit. Worked fine.
LONG time ago, swapped to the injen intake, no problem with flutter.
Went to the intercooler not so long ago.... decent flutter on partial throttle corner exit.
Suggestions.
Thanks for your time.
Suggestions.
Dave
Originally Posted by djh
Me too, I'd love to get rid of it. My car is stock except for a Buschur TBE. I'm not sure whether it's compressor surge or the BOV. My only thought on how to get rid of it is to turn down the boost, but I'd rather not.
Dave
Dave
Anyone else?
Originally Posted by bdking57
fyi .. kent jordan uses the stocker and pulls away from vipers on the straights. I think the stock Bov is the best solution.
To purchase a new stock bov, the plastic one, only to have it leak again, seems like a waste to me.
Also, you'll note that straight line power is not what i'm interested in, i'm interested in a unit that will not flutter at partial throttle. (corner exit). Any bov should hold constant boost at wot.
The forge unit i have might be remedied by more tweaking with the springs/shims, but i've tried about every combo to do avail.
thought about that, but also read about some higher than stock boost issues, so shyed away from that.
What I like about it is that it's almost the exact same size and shape as the stock uniut. Plus, it's annodized black. So you really don't notice it unless you specifically look for it. Those shiny BOV's seem to get service technicians panties in a knot.
Emre
i looked up the site you linked, what are you currently running for mods?
The forge unit i have right now is the same, black, but it's apparent i won't be getting any warranty coverage, unless i do some major removal
Also, what'd it cost?
Emre
I think your best bet would be an adjustable BOV you can tune to your specific mods. I'm using a WORKS / Go Fast Bits hybrid BOV. It is adjustable in how much VTA / recirc and spring preload simply by hand turning specific "knobs". When I first installed it using the WORKS recommended settings, it did give me slight partial thottle surge. Through trial and error I have been able to completely eliminate it (when set to full recirc) on the track. On the street I run with the quietest VTA setting and it works fine as well. I have a very large FMIC ugrade, and a bunch of other mods, so adjustable was the way to go. It's expensive, but the quality is top notch.
Lastly, make sure the BOV control line is as short and free of bends as possible - it made a noticeable difference in the partial throttle response for me. If you need a long line, use the hard pipe that is on the stock setup, it helps a lot.
gik0geck0
19
Feb 20, 2012 06:12 AM
