Shedding the weight... CF trunk & hood
#136
Originally Posted by nils
I am seriously starting to save $$$ to a full rollcage, I really, really need it.
You = a lot more expensive to replace than anything else.
Safe driving
#138
After all the discussion about crash worthiness. Let get back to the thread title.
Mr Robi,
can a Gt spoiler be mounted to the rear cf trunk? I was unclear after reading through the whole thread. Thanks
Mr Robi,
#139
Mr Robi,
Mr Robi,
#143
and some gratuitous car-**** of the CF parts that started this debate .
Long-term use feedback:
- hood fits great
- hood pins fit great, but needed some tweaking of the hood catch (slotting the bolt holes)
- hood pins hardware is not rust-proof (fixed it with clear nail polish)
- trunk fits great
- trunk will deform if you put trunk springs on it (even the no wing RS low tension version). I ground down the RS springs until they barely hold the trunk up when open, but the trunk still flexes a little. Also flexes if you push on the wing (straight back), causing the angle of attack on the wing to change slightly. This is a *small* flex, but with a bigger (or taller) wing than stock it may be more noticeable. The flex is in the connection between the trunk hinges and the lid. I haven't tracked the car since, so I can't say how much it changes the behavior of the car (if at all). A set of CF trunk hinges with a larger interface area would be sweet (and save more weight by removing the stock hinges).
#145
- hood fits great
- trunk fits great
#147
#149
You can't really shed that much weight from an EVO with carbon fiber hood and trunk. To really save weight you need a full set of carbon fiber DOORS without side braces. But don't get broadsided.
