SS Brake lines
SS Brake lines
Have a question regarding stainless steel brake lines. I added the lines a few days ago along with new fluid (Motul RBF 600).
I've heard people say that SS lines makes you better modulate the brakes. My quesiton is does the pedal feel tighter and the travel less with SS lines or is there more travel?
The pedal doesn't feel spongy, but it seems like there's more travel in the pedal after installing the SS lines. I think the bleeding was done right, but would like feed back on your experience with SS lines. please be as descriptive as possible.
thanks
thanks
Dave
I felt the same after the ss brake lines was intalled. The brake pedal needed to be pressed more before the brakes engage. Also, there seems to be more travel with brake pedel.
I installed stoptech ss brake line and used Motul RBF 600. I am planning to bleed the brake system this weekend to see if this will help.
thanks
thanks
interesting because i have the same lines and same fluid. let me know if anything changes after your rebleed.
The brake pedal feels a lot firmer after the rebleed
Did you do anything different for your re-bleed? Just bled my brakes, and the pedal is worse, spongy with lots of travel. Some people (and the service manual), recommend bleeding with the engine running. Did you try this?
Thanks!
Thanks!
Thanks!
Thanks!
There may be a how to in here somewhere about the rebleed. But I would suggest you rebleed again. Perhaps the person pushing the pedal did not push it all the way down? good luck
there is a very good write up in the how to forum
thanks
thanks
Always re-bleed the rear brakes after an install like that. I find that you don't get all of the air out of the rears the first time. Start with the right rear (inside bleeder then outside bleeder), go to left rear, then right front, left front, right rear again and then left rear again.
Hope this helps
Darin
Hope this helps
Darin
The SS lines feel good, and the car stops great. I bled the brakes right after the install, and then again after I drove the car around and noticed no difference.
Hope this helps
Darin
Hope this helps
Darin
Talon
11
Feb 24, 2014 05:38 AM
Western_man
16
Sep 15, 2009 08:27 PM
c900t16
Nov 8, 2007 07:06 AM
ries
Sep 19, 2005 07:06 PM
