Track whores with MRs?
Old Nov 10, 2006 | 08:42 AM
  #316
oneguy's Avatar
sweet, thanks
Old Nov 10, 2006 | 09:42 AM
  #317
voidhawk's Avatar
Some dp (e.g. WORKS) you can buy already coated. I had mine thermal barrier coated afterwards, but to be honest I couldn't tell you if it made a difference or not.
Old Nov 10, 2006 | 09:44 AM
  #318
voidhawk's Avatar
BTW, I saw that Power Enterprise makes an upgraded gear set for the 6MT (http://www.power-enterprise.co.jp/transmission.html). Something to consider if you're rebuilding your tranny anyway.
Old Nov 10, 2006 | 12:02 PM
  #319
JDMevoBOOST's Avatar
I'm gonna swaintech my ttp dp before I put it on. These threads are starting to scare me because I do about 8 HPDE a year and I couldnt resist a black mr, so I'm gonna try and work through this like the rest of you. Hopefully we can get a cost effective tranny cooler and other goodies to make this work.
If it blows I'll just ship it out to Jon, but I really dont want to have to do that if I dont have to.
Do you guys think it would be a cheaper/easier rebuild with the tranny still in good condition or wait til it blows?
Old Nov 10, 2006 | 01:02 PM
  #320
RazorLab's Avatar
The DP is right next to the TC, not the trans.
Old Nov 10, 2006 | 01:03 PM
  #321
RazorLab's Avatar
I see 5spd only.
Old Nov 10, 2006 | 02:33 PM
  #322
Fireball's Avatar
It's plenty close enough to the Tranny to heat stuff up. Seeing as how you only saw 10 degrees between normal and hard driving, I bet the DP could make at LEAST that difference being coated.
I still don't put my bets on this problem being heat related.
I wonder if anyone has tried putting a IX 4th gear in the 6spd... I believe they are different part #'s.
Have we had a confirmed IX 6spd blow up yet?
Old Nov 10, 2006 | 02:44 PM
  #323
redvolution's Avatar
I've heard the 4th gear from the 5sp is physically larger and beefier than the one from the 6 - i.e. it won't fit.
Old Nov 10, 2006 | 02:52 PM
  #324
voidhawk's Avatar
I think he was talking about the VIII 6MT vs. the IX 6MT - interesting question. Do we know if the IX tranny will bolt up to an VIII? I wonder what the differences are (other than the part no.).
Old Nov 10, 2006 | 02:57 PM
  #325
Wheelhaus's Avatar
5sp parts will NOT fir the 6sp and vice versa. The shaft spacing is 10mm different and thus will not mesh correctly. According to GEARS the 6sp spacing is 10mm closer. This also increases tooth face pressure as an added jab in the gut.
The IX 6sp (as far as I know) is unchanged from the VIII 6sp. Unless someone could prove otherwise, I believe swapping parts would be futile.
Old Nov 12, 2006 | 12:39 PM
  #326
hamflex's Avatar
This whole tranny problem is quite depressing, i just bought my 05' MR last weekend with intent to road race. So besides power enterprises, Any one else make gear stacks to perhaps fix this. Are the usdm MR gears the same as the jdm gears. Besides ratios maybe stronger. I used to be an avid se-r fan, but i thought i was done with tranny faliure.
Old Nov 12, 2006 | 11:25 PM
  #327
sblvro's Avatar
if you follow my post #311, the coordsport checklist for tranny parts show a bigger 4th gear for the IX 6 speed if fireballs part numbers are correct
Old Nov 12, 2006 | 11:29 PM
  #328
TTP Engineering's Avatar
That is an interesting thing to investigate.
Lets start a poll of the broken 6spd's 4th gear and see if we can locate mileage, fluid type used, type of driving, 2005 or 2006 and see if we can further pinpoint anything important.
What I do know is that pre-June '03 5spds have a smaller 5th gear than the June/'03+ Evo 5spds just to throw out some data on the other trans.
Old Nov 12, 2006 | 11:39 PM
  #329
voidhawk's Avatar
so when you guys say "bigger" do you mean different gear ratio or same ratio and more material to make it stronger? Also would there be room in the VIII 6MT to fit a "beefier" IX 4th gear? There may be some hope for tracking the 6MT after all ...
Old Nov 13, 2006 | 08:31 PM
  #330
Wheelhaus's Avatar
"bigger" means "fatter". The problem is the witdh is a scant 14mm. The ratio would undoubtedly be the same but the profile would be meatier to make it stronger. Let's hope this is the case wih the IX MR's, we're just waiting official measured confirmation from someone who has torn apart a IX MR tranny.
From what I've gathered, the 5sp and the 6sp share the same case width, so the 6sp gear profiles are narrowed to cram in the 6th gear. If the IX tranny has been "updated" then the gear profiles were likely thickened for the upper gears, and thinned for the lower gears so they'll all still fit into the same space. This is a hugely optimistic guess, though.
