Track whores with MRs?
#361
Originally Posted by Wheelhaus
1- how would you know when the case is "full", I assume do the math to figure the added volume of the pump, hoses, and radiator unit?
2- would running without the pump turned on cause a problem by overfilling the transmission case?
#362
Originally Posted by razorlab
TRE told me to fill the trans , then turn the pump on, let it prime and fill the cooler and lines. Then fill the trans till its full again, rinse and repeat until fluid is always coming out the trans fill like how you would normally fill the trans.
I had this concern too but after looking into the specs of the Tilton pump I am using, it uses a diaphragm that won't let much drain back in if the pump is not on. Also, the way I have my return line on top of the trans the fluid would have to go up without the pump on to get back into the case, and the diaphragm should stop it from draining back through the pick up line. Again, after I get off my lazy *** and actually get everything installed I will have more information for everyone.
#363
doh! thanks for the corrrection. I could have sworn one of the BG's are dino.
#364
Marty
#365
Originally Posted by Galant VR-4 #34
the pump is very very loud so youll know if it is on.
Marty
Marty
I am going to try and wire it to my foglight switch so the little fog light icon lights up on the dash when it's on so I know for sure it's on or off. We'll see if that switch works.
#367
Originally Posted by mrfred
If you aren't already using rubber isolation pads, you might want to try that if the vibration gets too annoying.
The con about mounting it under the MAF is that I can't ever upgrade to the more straight IC pipes that route right through there. Oh well.
#368
Trust me you wont need a light to know its on, it is that loud once you run fluid through it. The insulator doesnt help much at all, id put it on but I couldnt tell much difference from mine without the bushings to my buddies with. I never run my pump on the street (yes my car is still streel legal). Its just way too loud and annoying to run around town, strictly a track use thing. As for lines, I went with the longest lines I could get on the car, mine total over 10 feet, the reason? more fluid
Marty
Marty
#369
Hey i was wondering, Do you think running a lightened flywheel would make a differance? On and off the throttle through turns or straight line, wouldnt it help in putting less stress on the transmission?
#373
#374
I run this set up on my Evo race car for 40 minute national races and many more practice laps and quals.
#375
I assume you're running the 5sp? And I'd also assume you've done some other work to the transmission as well including periodic overhauls...
Marty
