Interested in hearing input from you TTA guys...
#76
992 - Ya they are the "roll center correction" kit, which IS just an adjustable tie rod end. So i guess it would add something, if so how much?
Bueller - according this this rule "Note: vehicles with headers and downstream aftermarket exhaust are assessed a total of +4 with a catalytic converter,
and +5 w/o a catalytic converter, regardless of the OEM setup." Since we technically DO have a header, and the rest IS aftermarket, would that be it?
...the regardless is what's making me doubt.
#78
Since your base class is TTB*, don't forget to add in those 7 points right off the top. Roll center kit I was thinking was +2 (Alteration of Ball joints/Dive Angles), hopefully not relocation of suspension mounting points (+6). I'll ask the National TT director next week for a ruling on that one.
Technically we do NOT have a header, it's an exhaust manifold. So aftermarket turbo-back and no cat - +3 If you installed a tubular header, +2 more.
#79
Sweet. So minus the two from the TBE and i'm at 39 exactly. I'll ask about the rod ends, because they are only for alignment purposes so it should be aight. Now all i have to do is get better and fix my bov from sputtering.
#80
If you want to stay in TTA, im pretty sure youre going to have to go with the stock undertray, otherwise youre going to get assessed points for it which will bump you out of TTA. Pretty much everything that you add/change, that isnt a no-points mod, will be assessed points. Either way, youre going to have to go over all of this with your TT Director when you sign up.
#81
Ok guys, read this whole thread, and using the rules from the NASA TT website, here is how I breakdown, if I made any mistakes, please help me out with them.
Evo IX MR - TTB* (+7)
Enkei NT03+M's/Nitto NT-01 275mm (+5 and +1)
Rear Bumper support removal (JDM Rear) (+1)
Flashed ECU (+10)
Buschur Intake (+1)
Buschur Boost Controller (+4)
Buschur TBE (No Cat) (+2 and +1)
Robispec Clubsports (Planned coilovers) (+9) (?? Read that on page 5??)
Progress Rear Swaybar (+2)
Whitleline Ball Joint Extenders (+2)
Autopower 4- Point with Harnesses (No Points)
AMS LICP (Included with Intake mods)
GiroDisc 2 Piece Rotors (No Points)
Raybestos ST-43s (No Points)
That all adds up to: 45 Points
I figured I could get the suspension dialed in enough to dump the Rear sway (-2) and dump the MBC (-4) and have the car tuned for 98-100 oct. using ECUflash to control boost (21ish psi ??) With those removals, I should be at 39.
Remove Rear sway (-2)
Remove MBC (-4)
That should put me at 39 points. Did I miss anything or make any miscalculations?
Thanks
-Ryan (Hopefully TTA!!)
Flashed ECU (+10)
Buschur Intake (+1)
Remove MBC (-4)
Thanks
#84
Warrtalon,
Thanks for the info! I didnt have my car stock very long, I don't remember what the PSI is/holds, but for road racing, I'm generally not looking for alot of boost (playin it safe/reliable). As far as a tune, I was considering havin AMS do it because I plan to hit another HPDE at Autobahn yet this year. Most tracks, that I've been to, have 98/100 + available, I'm hoping with a tune for high octane fuel with stock boost and my above mods will make decent power...and let the suspension setup/driving make up for the rest.
-Ryan
-Ryan
#88
If you take points for an ecu flash, you're legal with doing the boost INSIDE the ecu, again, can't swap any of the boost lines, or the actuator.
Nasa's very simple. Just ask greg.
edit:
again, the rules will probably completely change again for next year, so the setup that sounded sweet this year, will probably be over-pointed.
#89
Just added it up and I think i nailed 38 points, here's what i've got:
06 Evo IX - 325 awhp - 9.94 P/W ratio (I think)
Parts with points
9.5'' Eneki's with 255/40/17 NT-01's (rules said you could subtract 7 points being they are 30mm less then the 295 rule) -1 +5 = +5
Robispec KW Clubsports 9k front/10k rear (they do have that "remote" res. attached) + 7 +2 = +9
Flashed ECU +10
Injen Pipe's/filter +1
Turbo XS intercooler +4
Perrin TBE w/o cat +3
Progress 25mm rear sway +2
Forge MBC +4
Parts without points
Whiteline tie rod ends +2
Whiteline rear control arm bushings (is this the bump steer kit?) +2
PFC front rotors free
OEM rear rotors free
Raybestos st-43 pads all around free
M-1 Harness Bar free
Schroth ASM-FE 4 point belt free
Shifter base bushings free
Did i get it right?
Parts with points
Flashed ECU +10
Forge MBC +4
Did i get it right?
#90
Right, you can modify the boost tables in the ecu, but the lines under the hood and the pills have to remain stock. Otherwise it's +4. Also, there is no way 255's are big enough for an Evo in TTA. Stock-ish Z06's play there and have enough points available to run 295 Hoosiers....
