How to make an AWD car rotate
STaSiS engineering has it right...
In car video with Chip Herr at Miller Motorsports park
http://www.youtube.com/watch?v=WFLSPGdeinQ
Notice how the car has ZERO understeer... i've never seen any in car video from an evo that looks like this. I called STaSIS and they said they work with the rear diff and rear valving to help with this. They also said its alot of Chip using left foot braking.
-Kyle
-Kyle
With just a Cusco rear swaybar, an aggressive alignment (including rear toe-out), and lots of trailbraking & left-foot braking, I find even my relatively stock 2003 Evo VIII is pretty neutral. With properly tuned coilovers and the appropriate driving style, there's no reason why a track-prepped Evo should understeer.
Emre
Emre
No understeer...but a good deal of oversteer on exit....this car would be difficult for the average driver...but as they say, loose is fast, if you can catch it.
I don't ever seem to have too much understeer.... For me, it seems to be easily controllable by doing the following:
(Turn 1 at Road America)
Corner is a 80 or so degree to the right. Entry speed is around 60-80mph. Brake hard coming down from 145, start braking at marker #4. (#5 if you want to play a little safer). Get into 4th, just at about corner entry. As you turn in, lift off brake and apply a little throttle. Once you feel the car settle into the corner "groove", squeeze the throttle to 100%. The car then feels like it "pushes" the rear end of it through the corner, creating a touch of oversteer on corner exit.
There's been times I've lit all 4 coming out of a corner using this method, and I'm not pushing any crazy amounts of HP.
I also didnt have an understeer issues until I started driving 10/10ths. I want to make it clear that understeer in the evo sometimes doesnt show its ugly head until you start pushing the car past its limits.
all im trying to say is that evo's dont handle like that audi.... someone please prove me wrong by posting a video... I'm talking about corner exit push BTW.
Yes, I understeer all over the place with corner exit push and with late braking while trying to get every last millisecond of acceleration before the next corner. I guess I overdrive, but understeer is very apparent all the time with me, or at least it was at every event with the stock suspension.
adding 275 Hoosiers 1400kg springs in the rear and a 27mm rear swaybar will win time trails and be the fast car on the track... but it wont be as fast as a car that can rotate like that STaSIS audi.
I think we need to start getting creative
I'm going to try some crazy toe out front and rear ... maybe -1.30 F -1.20 R
-Kyle
Emre
Its not to hard to do, but it does cost some $$$
List of Parts:
Coilovers 12k Front, 14k Rear (Give or take 2k depending on driver or track), on something that can handle them JIC FLA2 revalved. Motons, Ohlins.
Front Sway Bar Cusco 21mm Or GSC Comp Bars (Avalible 2-10-07)
Rear Sway Bar Cusco 23mm, Hotchkis Rear, Progress Rear Or GSC Comp Bars (Avalible 2-10-07)
1/2" front wheel spacers With ARP Wheel studs the further out you can push them the better. if ur on stock wheels 3/4"
Front LSD for 03, 04 cars (excluding RS)
40/60 GSC Center Diff ( Now avalible)
boom their you go, one overstear capable EVO
List of Parts:
-Kyle
-Kyle
