Magnetic Numbers?
I got mine from here... same as Talon mentioned above.
http://www.edecals.com/custom/door_numbers.html
Here's how it looks:
http://solotime.com/index.asp?PageAc...ProdID=21&HS=1
Probably one of the cheapest places on the net. Good stuf too.
Solotime Autocross-Track Day-Race Car 8" Magnetic or Reusable Number Package
Solotime ™ magnetic numbers have been seen on the cover of 'SportsCar', 'Grassroots Motorsports' and 'North American Pylon' magazines. All magentic numbers are not the same. We use quality .030" thick magnetic sheet stock with a colored plastic mylar bonded to the top surface. The corners are prefectly radiused to prevent tears and give greater durability. They are permanently magnetized to give years of use.
Our Autocross Number Packages include the numbers (8", 10" or 12") and class letters (5") you need for both sides of the car. By purchasing a package, you save close to 10% on the order. This kit includes up to 3 digits for the car number and 3 letters for the class designation. HINT: Even if you only need a two digit number, add a "1" to your order in case you ever have a co-criver!
Select the color you want, and the font. Then enter the number and class you need in the box below. In just a few days, we'll deliver to your door a high quality, long lasting set of magnetic numbers that you will be proud to display.
