Trying Hoosiers after Running R-Compounds?
I have been running NT-01s for my last several track days in the Evo, at the big track at Willow Springs, and Streets of Willow. Before that I used RA-1s for years (started out using full tread, then switched to shaved). I like the NT-01s much better.
Now that I am running faster than I used to, I am using up a complete set of NT-01s in about 2 1/2 track days. I run a lot, figure 3+ hours per day. This is much faster wear than I got out of the RA-1s back when I wasn't running as fast.
So I am thinking about switching to Hoosier R6. What's another $50 per tire between friends? I run on stock Enkei 17 x 8 Evo VIII wheels (I have two sets). The size of R-Compounds I use is 255/40/17, but Hoosier doesn't make that size, so I would have to run 245/40/17 R6's. Don't suggest that I should go to 275/40/17 (or 18s) because that would mean buying 8 new wheels and modifying the wheel wells.
I'm looking for input from road racers who have switched from R-Compounds to Hoosiers. Especially if you know the road courses in SoCal. How much time do you think I could pick up by running Hoosiers on, for example, Big Willow, if my best lap time so far on R-Compounds is 1:34.9 ? Same question for Streets of Willow, best lap time on R-comp is 1:26.8. Thanks!
R6's dont like to 'bulge' from being too wide on a narrow wheel. What size wheels do you run? I'm not familiar with "Enki 15 x 7" -you're running on a 15" wheel?
I'd run the 245/40s...
Ooops. I meant Enkei 17" x 8" stock wheels. (I got confused with my Miata race car that has 15 x 7s).
255 is pretty wide for an 8" wide wheel. I definitely wouldn't go larger than 245 for the Hoosiers. "Usually" the R6's are about a 1-1.5 seconds faster than RA1/NT01.
But FYI - when I back to backed shaved RA1s to improperly sized (too wide tire for wheel) R6s, the RA1 felt better, put down the power better, and was faster.
Richard, as you know, everything is a compromise. But imo i think youre losing a great deal of time with that setup. If your car is putting down the amount of power as before, i seriously think you need bigger wheels/tires. Since you already have 2 sets of wheels, i think its great that youre going to stick with your current wheels/setup to try things out. But i honestly think you will greatly benefit from bigger wheels/tires. Once my car is setup properly for TTA, i will be able to tell what i really think.
If youre looking for more concrete info, look at Jasons times. At our May TT event at Big Willow, his fastest time was a 1:32.33 on JICs, and 275 RA1s. And his power mods were basic, ie 100oct flash. And iirc, he had a cat. Either way, those times totally make sense to me. I dont recall what suspension youre running, but if you still have the same power as before, i think you can easily do 1:32s with your current setup, ie 255 NT01s.
Not that I fit the profile of folks you wanted to talk to but... I was in the boat you are in that I wanted better performance from my shoes and was running 255 rubber on stock rims.
I do not like the loss of feel from running rubber thats a bit too wide so I'm actually biting the bullet and getting some 17x9.5" wheels. I will run the same 255 rubber and think I should see much better performance from them. In the long run I hope to see better tire life and make some of the money back I am spending on the wheels.
As for suspension, I still have the same JIC coil overs and rear sway bar I got tuned by Mueller long ago. Lately Robi has been aligning the car and adjusting the suspension, and he managed to get some of the push out last week, but I think I have outgrown this suspension. Robi's KW set-up is $3500 and Mueller's Moton set-up is $5200 (both include labor). I'm not doing either one anytime soon.
The reason I don't want to go to 275's on 9.5" wide wheels is cost of wheels, tires and fender mods. I need two sets of wheels the same size. If the Evo was my only track car I wouldn't mind, but I'm spending a bundle right now building the Miata into an SCCA club racer to run in ITA. Full roll cage, fire suppression system, kill switch, new expensive racing seat, Hans device, racing suit, new gearbox, limited lip diff, etc. etc. It adds up.
If you want to reference tirerack, here are a few other options:
$239 - 255/40 - R1 (only one that comes in 255/40)
$237 - 245/45 - R6
$195 - 245/45 - V710
$199 - 245/45 - Z214 (Tirerack doesnt carry these)
Although, considering how much you drive at every event, you are going to eat through these tires significantly faster than the NT01/RA1. Just another thought.
$237 - 245/45 - R6
Hey Richard,
Personally I wouldn't make the move to Hoosiers. Knowing how much you drive, your tire budget is going to skyrocket. You will be better off as Ed suggested by going a little wider and picking up a set of Motons.
For what it's worth, a little wider of a tire and Motons on your car should get you to a 1:30.x and possibly break below that elusive time on a good day. Turn 9 was always my achille's heel in breaking that mark. I think I just watched Kent's video one too many times.
Hey Richard,
Nice to hear from you. Where have you been? Since I am running high 1:34's, I'm a long way from 1:30's.
The one place I'm sure I'm leaving speed on the table is Turn 9. Not carrying enough speed through it or getting on the gas fast enough when pointed at the apex. That translates into lower terminal velocity at the end of the front straight. I think I could make up a second just learning to take 9 ***** out. I always feel like I could have taken Turn 1 faster, and I'd like to find a quicker line trough Turn 4. The rest of the track I think I'm pretty close to my car's limits. Robi thinks he could run a 1:31 in my Evo and I don't doubt it.
For those of you who don't know it, here's the track we're talking about. Turns 3-4-5 are a hill, and Turn 6 is a rise. Turns 2, 8 and 9 are banked.
I have to agree with others and say you need a wider tire. I would think the added squirm and movement of a 255 on a 8" rim would be slowing you down. You can move to a 17x9 for pretty cheap and run that 255 just perfect.
It doesn't sound like you'd want to move to a 9.5" rim to run 275's; but it's done a lot. NT01/RA1 both work here for about the same price too.
Another more expensive option is running a 265/35-18... I think running Hoosiers is going to be a very expensive upgrade. I've never ran them, but I'm assuming they wear a lot faster.
FWIW; here's some info on tire width:
Nitto NT01 245/45-17 - 9.72
Toyo RA1 255/40-17 - 10.20
Nitto NT01 255/40-17 - 10.35
Toyo R888 255/40-17 - 10.44
Toyo RA1 275/40-17 - 10.90
Nitto NT01 275/40-17 - 10.91
I'm not a big fan of running a 255 on a 9.5" rim either. That's a bit of a stretch; but not too bad. Just my .02
