Team Robispec to Nashville Redline Time Attack
1st - James Elterman - Takata Time Attack Subaru STI - 1:06.633
2nd - Robert Fuller - Forged Performance / Robispec Evo 8 - 1:09.565
3rd - Taylor Holland - Robispec Evo 9 - 1:09.567
^ that was close between Robi and Taylor for that 2nd place. Wish my buddy and I could have made it out but both are cars are down for a bit. We will try to see if I get my parts soon and my buddy gets his car all put back together soon to try to make it out to summit point. Good luck to all that are going out and hope to see you there
I had a great time this weekend! Didn't expect to have all the problems I did, but we got um worked out, and I was able to pull out a 3rd place finish. I want to thank Robi, and the guys at Top Speed. Top Speed, you guys are great! I really appreciate your help with my tuning on sat night. Congrats on the record breaking run!
I would also like to say again for the 1000th time. Robi's Clubsports are the bomb didity! He beat me by .002 yes, but looking at the 2 cars side by side I had a HUGE HP disadvantage. My car running 10.0 AFR's "might" make 360 to the wheels, where as the blue VIII was making every bit of 500 to the wheels if not more. I lent my tires to robi for the last timed session, so tires were the same (R888's). The VIII was on swift springs and I was on 2yr old clubsports. Also, Robi is a much more skilled driver than I.
So one might say...This weekend it took an extra 140ish HP to basically match my underpowered clubsport equipped evo. I need a ride to VA!!!!
Taylor, this is Ryan (owner of the blue evo) Thanks again for all of the help this weekend. We couldnt have made those passes without your tires. It was a pleasure to share garage space, tires, and tools with you For the record the car made 533.5whp on the Dynamics Dyno(heartbreaker) @ 27psi. We were running on 20psi due to ignition issues, so I believe we left alot on the table. I believe the car makes around 425-450ish at that boost level. Your car drives circles around mine in the corners, thank god for that long straightaway
You NEED to come to WV in 3 weeks. Im counting on you to be there. Ive got a few surprises for you there Once again, thanks for everything Taylor!
yodaman
40
Jan 5, 2009 02:48 AM
robi
12
Apr 2, 2008 09:04 PM
