BSP - TRE Rear Diff Question
It takes a big man to apologize.
Anyhow, in terms of product sales... what does TRE actually recommend? I'd bet he could make some interesting custom stuff for off road applications. I wonder what a diff best made for snow would behave like?
Back to your regular programming....
Anyways, back to the rear diff topic. You are completely correct in that 1.5 way is prefered for road racing application because it provides that extra bit of stability during braking (especially if you like to trail brake at higher speeds). Having the rear swing out on you @ high speeds is no laughing matter.
As you know, the 1 way diff acts as an open diff during decelaration (no power) allowing greater difference in wheel speeds which allows the rear to turn easier. Probably makes sense in low speed auto-x type of events, where you need the rear to swing out quicker. That is why when power doesn't overpower grip some drivers actually prefer open diffs. Hope that made sense ...
Regardless, I'm the type of guys that believes to really give an educated answer to the question there is no alternative to testing both diffs out on the same car with the same setup. I mean, looking at the math, with the % lock up characteristic during accel and decel are fine but until you put both on a car and test it, we're all just guessing. Which for most might not be financially possible.
In the OP's case, 1 way or 1.5 way may work best for him but it depends on a lot of factors, eg: driving style, suspension setup, power level, tires, speeds, etc ... which we know nothing about, so to try to give a very specific answer to general question kinda defeats the purpose. Regardless at least we can help him narrow it down to 1 or 1.5 way. Depending on how he drives and sets up his car a 1.5 way diff can work as the % locking characteristics of the diff can make a big difference .... as for which is faster we won't know until someone tests both and posts results ... Any volunteers?
perfectly legal, diff's are unrestricted in SP.
I would recommend the maxlock. This has given me a lot more flexibilty in my suspension and alignment as I have more oversteer than I have ever experienced in my EVO.
getting the suspension where I want has been a bit of a challenge on a "no-money" race budget, but the changes in handles were dramatic and well worth the cost of the TRE diff.
https://www.evolutionm.net/forums/6869751-post119.html
I also totally agree about the TRE diff. I love it.
Diffs are pretty open in SP. It also looks like modifying the ACD is not legal. Jarrod quoted some rules here:
Import Junky
16
Jun 28, 2008 04:45 PM
