APR GTC-200 2.5” Riser?
Yeah, it is right at the roofline. Yes, it's the GTC-200.
See pictures here: https://www.evolutionm.net/forums/7172349-post17.html
Also see the newest video here: http://www.flatlinemotorsports.net/Video_Vault.html --The camera is mounted rearward at ~ 3:25.
I CADed it up and sent it off to be made. When I asked APR they said that they had one in the works, but not that big.
It helped tremendously by giving my rear view back. Now that I've turned down the power I actually have to use that mirror again. lol.
2.5" isn't enough for me...
9" FTW
9" FTW
I own the same rectangular aluminum wing supports from APR but if you are going to do something trick make molds with foam and build wing supports the way they are suppose to be made. Look at the new factory Dodge Viper ACR wing supports. They are air foils. The front of the support should be blunt and the rear feathers to a point. Vertical winged supports. That's the correct way to make them. Somebody needs to take the time to sculpture foam. Then figure out the best way to attach fasteners to the finished molded piece. No drag, light weight aerodynamic supports, that's what we should be creating! Not these boxy aluminum erector set supports.
It's not that the stock GTC 200 height is useless, but if you want to optimize the wing's downforce, you need raise the wing up into cleaner airfow.
Even on a fastback sportscar, RaceCar Engineering wind tunnel tested that the wing height needed to be 1.5x of the wing's chord width. On an Evo with its bad sedan rear window - trunk angle, the wing needs to be significantly higher.
Look at how high AMS's wing is, along with other successful competition Evos.
Rick
Rick
Dave99gst
Mar 28, 2016 05:55 AM
stck_trbo_mnstr
Jul 5, 2012 11:17 PM
