Lime Rock crash
Totally worst case. Low to the ground, driver left lean looking at the outside of the corner, dove inside meeting a staled lotus aka launch ramp. Thinking maybe .05 seconds between his maneuver and the impact. Along for the ride at that point. Still curious though how his neck got broke....because the neck is technically the most protected part of the driver if it's all hooked up right. Normally the hands/arms or feet/legs break because the fly around the cockpit banging into steel when you go air born. Hoping to learn and maybe improve our setups based on the results.
i thought it is a mandetory already in any kinda of road race or circuit and rally already.
Or maybe wasn't tight enough...
The real scary thing is that could have easily happened in an HPDE where safety gear is often at street car levels. Nothing about that crash is "Oh, that's because it was racing. That wouldn't happen at an HPDE." Terrifying stuff.
But yeah, scary video. I read the comments first, so I knew to expect a crash, but it was still quite shocking to watch.
And I can't imagine the car in front given you a point by when there is a backwards Lotus in the middle of the straightaway.
But on the HPDE note, there are the run groups that your allowed to pass in the corners or even get up them in the corner and wait for the pointby so you have the momentum. However, i'd agree that ~50% of the time you wouldn't be THAT aggressive with your draft being you wouldn't be in a race condition. Some cases that would have been black flagged. Depends on the people/group involved.
Ill add too, depending on the event/day, the advance/usally pro groups do not always have to point by either.
Correct. Talking advanced run groups here. I would never want to see a novice doing that sort of overtake. But it does happen in HPDE - so that danger is there for sure.
I was simply addressing your specific comment "Coming off a sweeper on the tail of someone, pointed by, I would swing by carrying my speed. " ... The odds of you being pointed by in a situation like that are negligible.
Yes, situations like this could happen in an advanced HPDE run group... hell, I guess any run group. Anything can happen on the track.
But, I think saying that a situation such as what happend in this video could have "easily happened in an HPDE" is a bit of a stretch. There would have to be a very specific set of circumstances to allow this type of accident to take place in HPDE; ie: 2 advanced drivers practicing lead/follow, passing without using point bys, drafting/driving in a very aggressive manner. Could it happen? Sure. But most HPDE organizations do their best to ensure things like this don't occur.
And if you are a novice driver and are running with an organization that doesn't enforce point bys, you may want to consider taking your business and track time elsewhere. Open passing has no place in novice/beginner or even intermediate run groups. That leaves far too many variable open to chance, in the hands of drivers with limited experience.
My $.02
