Nasa tts class
Old Oct 13, 2009, 12:59 PM
boomn29's Avatar
Originally Posted by MitsoKid
That 3,210ibs includes no gas, me in a sparco 1 piece racing seat, g-force 5pt harnesses.. It does not include a passenger seat or passenger harness.. The helmet doesnt weight to much..
I thought the min. comp. weight is the absolute smallest amount of weight you can have wth the driver. So I assumed this meant no gas.. I did weight it will half a tank and it weighed out to 3,258ibs
Good.
And you're exactly right about the 'min competition weight' there. But if you've spent anytime on a road course and taken a hard right hander; you'll know what I mean about the fuel!!
Old Oct 13, 2009, 01:06 PM
boomn29's Avatar
Originally Posted by Bueller
I race in Super Touring 2. The equivalent TT class to my race class is TTS. For every PT, ST, and SU race class there is an equivalent TT class. NASA has it setup that way so that TT guys can easily transition into racing if thats something they want to do some day.
TTS = ST2
TTU = ST1
TTR = SU
Ed, you ran in ST2 with the stock turbo this year right? I don't think you were maxed to the 8.7:1 modified ratio, but were close right?
Any issues in your longer races with heat out there in CA?
Old Oct 13, 2009, 01:10 PM
MitsoKid's Avatar
some quick pics..
The interior is still a project that needs to be tackled.. Its proving more difficult that I originally thought it would be
Old Oct 13, 2009, 01:42 PM
Balrok's Avatar
Pick up the tts/r/u classification and rules form on the website, and you'll see all the rules. Basically you can do just about anything so long as your hp/weight + misc points match up (see boom's notes). So yes you can do a CF roof. A red on a stock 2.0 with low boost is quite inefficient, unless you want to build for TTU. From the looks of things your half way between U and S, so I'd make my decision and then design towards that. But remember with U though, your gonna spend a lot more dough to be up front. Your going to need massive aero, and better brakes to stay up with those cars.
Also, as you might have seen/heard/been told before, a "bolt in" cage is frowned upon in almost every club, however it's better then none as a lot of the TT guys lack. So my advice:
1. Put the stock turbo back on if your sticking with a 2.0
2. Get weight down so that you can keep the boost below ~28 psi
3. Weld in the cage or tac even, or build a custom one.
4. Get a nice racing seat WITHOUT the adjustable rails (they will move, and they put you up higher)
5. Get a nice fire bottle or better yet a system, cheap insurance if you get hit or hit someone or a wall or catch on fire due to leak, etc etc etc etc
6. Use a hans or simular device with your helmet/harness
7. Have someone sort out your alignment and corner weight for the tires you get.
8. If you have the money, get a traqmate or simular so you can coach yourself.
9. Depending on your region's weather, a coolsuit is the best driver assist ever.
10. Lots of gauges so you can monitor your car easily while on track.
Old Oct 13, 2009, 01:51 PM
Bueller's Avatar
Before Nationals, thanks to RRE, i upgraded my turbo to their GT3076. If we get my car repaired in time for our Nov races, that will be the first time my w/p will be maxed out for ST2. Although, we may be changing my setup after that, so i may not keep this turbo.
Other than that i have been racing on my OEM Evo 9 turbo for all my Socal Regional races. I was never maxed out with that setup for any of my ST2 races. I dont have the data with me, but my w/p was never close to 8.7. The lowest w/p i ran was during my ACS races, which was probably somewhere around 9.5. At my BRP and Big Willow races i was anywhere from 9.8-10.3. So i was never close to our limit of 8.7.
As for the heat, i never had any heat issues in any of my races. And the hottest races i had were at Big Willow where temps were in the low 90s.
Old Oct 13, 2009, 02:25 PM
MitsoKid's Avatar
you actually said alot of what I was thinking. I am going to take more weight out where I can.. Heat.. A/C.. Ect.. I already have an appointment with draco performance for a tune, fender rolling, and a complete balance on their corner scales. Unfortunatly I went to the FP Red because I had an oil cooler line break and it toasted the stock turbo and #4 piston .. I actually picked up a brand new Red for $1,800 with manifolds, SS oil lines and everything..
I was going to replace the roll cage but I picked that one up for $300 almost new. I was actually thinking of welding it like you said... I want to elimite the seat bracket setup I have now.. Actually its not adjustable. i mated 1/4 6061 aluminum plates to the lower portion of the factory rails.. Im not sure how to get it lower though.
Im really on a tight budget. I shouldnt be doing this but its my dream and i have the passion to make it happen.. And a coolsuit is a must in the southeast in summer
Old Oct 13, 2009, 02:28 PM
MitsoKid's Avatar
Also i was thinking that if I ran a 245.. Which would work better on the wheels I have, that I could take my weight down to 3,201 and still have 400hp.. This would make better use of the bigger turbo
Old Oct 13, 2009, 02:34 PM
goforwand's Avatar
I'm on a similar (albeit delayed) path...
Started with an in tact wrecked Evo (parts sold from it more than paid for the car) and stripped it from head to toe
After looking at the options in terms of classing, TTS was where I wanted to be because the math is simple
Priorities..(order can vary based on check book balance)
1. Safety
2. Safety
3. Safety (did I mention safety?...)
4. Weight
5. Suspension
6. Tires
7. Brakes (only because I don't have the $$ yet for stoptech's)
8. Aero (work in progress, but this is where the flexibility of TTS is great)
9. Reliability mods
10. Engine and tuning
I'm hoping to get the car right around 2850 lbs dry; which if you saw the pile of metal and assorted junk that came out of the thing, is a realistic target.
I can essentially run a stock motor (saves money to throw away elsewhere) until it blows up, and then switch to a 2.4
TTS isn't the best place for an Evo and I know that; but if I focus on the biggest most important mod (the driver) it will be easy to measure improvement...
Old Oct 13, 2009, 02:37 PM
MitsoKid's Avatar
1. Safety
2. Safety
4. Weight
5. Suspension
6. Tires
9. Reliability mods
I think you hit the nail on the head with your goals and priorities...
The first thing I got was that AutoPower NASA legal bolt in cage, then a pair of Sparco's, then 5pt harnesses that i made custom, welded in mounting plates for, then a quick release steering wheel.. Only thing I lack is a killswitch and a fire extingusher.. and possibly welding in the AutoPower cage or making a custom one like mentioned before
I dont have much as far as aero goes. I did manage to pick up a full set of StopTech BBK's and Brembo GT BBK's for just $400 off a rally team.. I got so lucky on that one. Funny thing is that I have had Evo guys tell me to go back to stock? I love these brakes.. What I have found is that the StopTech front bbk matched with the Brembo GT rear BBK lends itself to a very good balance. The rear end stepping out is eliminated and the transitions are smoother imo
At a dyno day at Draco Perfomance in Cornelious, NC.. I let an engineer who was there for Performance Friction drive my car.. He loved the balance, he was very suprised with the braking.. then he tried to sell me PF Pads, lol
Old Oct 13, 2009, 03:03 PM
Bueller's Avatar
Its good to do your homework and have a plan, but there is a limit when you are a noob. And this goes for anyone else reading this thread who is planning/building for any series. You need to at the very least get out there and compete for a season before you start making a list of mods you want to do. Ask yourself this question...how can i expect to build for this class when i have no experience with it? So keep things really simple for now. Forget about power and everything else for now. Just make sure your car is reliable overall, and start competing.
The only thing ive really spent money on in the past was on my suspension with another shop. That is another story in itself. Beyond that, ive really only spent money on safety gear (required for racing), and consumables. I just recently upgraded my turbo, but i only did it because it was through my sponsor. And i may not even keep this turbo. Beyond that the rest of my car overall is OEM...OEM aero, OEM diffs, OEM engine, and so forth. I have modified many things, but its been a gradual build that has been progressing. And ill be modifying it more accordingly.
Old Oct 13, 2009, 03:29 PM
MitsoKid's Avatar
that sounds very realistic to me and goes along with what I think. The thing is, since I have to run new tires anyway, why not go with the proper size and get used to it.. Im not used to a 245, im used to a 255 or larger... So Im realistically reducing consumable cost and preparing myself for the small adjustment..
Also since I have a blown motor, I am going to up the compression ratio so off-boost response is better. That way I dont have to be all out in boost to have fun, which is my goal for the first year or so. This should make things a tad more reliable, not much, just a tad
After that I wouldnt mind getting a bit more serious about sponsors if I prove myself
Old Oct 13, 2009, 03:42 PM
Ludikraut's Avatar
As far as I can tell, one of the best turbo setups for TTS would be something like an FP Green. You want early spool to max out your torque and then taper towards redline to still come in under the HP limit. All this, while not pushing the turbo so hard that heat becomes an issue ...
l8r)
Old Oct 13, 2009, 03:49 PM
GST Motorsports's Avatar
l8r)
Something like this?
- Bryan
Old Oct 13, 2009, 04:18 PM
MitsoKid's Avatar
yea see there is my problem.. on the red, right about where your turbo there is maxing out and starting to slope down, mine is just getting up to spool.. i have a sh*tton of top end though.. But no torque like you said
Old Oct 13, 2009, 06:44 PM
kyoo's Avatar
Anyone know if the CF roof is legal for sure? that's the roof, not hood or anything.
Quick Reply: Nasa tts class
