Need advice on braking and cornering
AWD should be able to go in WAY faster than RWD. Honestly, the car should be able to trail a ton of brakes into the corner, just like a FWD car. It should then [ideally] come off the corner all nice and tidy like a RWD car. If you can't carry your brakes into the corner, in most issues, almost to the apex, then something is wrong. It sounds like a rear ride height issue personally, but it's impossible to tell from a forum. Get some video, and even better, if you can get some data we could address the issue better.
Did Robi setup your KW's or did you just slap them on? I know they have a ton of adjustment and come severely out of whack from the factory sometimes.
What's the ride height now? You could just try sticking a few fingers between the wheel and the fender and measure that way if nothing else.
Take a string and tie a bolt/nail to it. Now hold the top of the string against the rim of the fender so that the bolt/nail lines up against the hub/center of the wheel. Now measure the length of the string from the hub to the fender.
I have always counted the threads on my coilovers! Haha
On my clubsports it was 22 threads in the rear and 3 in front! Haha. I never had the car corner weighted on the KW's though. So I made it equal all the way around. on my old set up that was corner weighted I would go up let's say two threads at a time on each side. Its fast and easy and good for trackside adjustments.
Not knowing where your shock valving is set I would back down on the rear rebound.
If the corner weights were off you would feel a difference between left and right turnins.
Do not fret over the ride height, it will not make any difference.
I know mike and I know he is new to this, im sure with a few more track days he will figure everything out.
Hey Mike how were your brakes all day? did you begin to lose them at all, any fade as the day went on or at the end of every session?
ride height is such a huge impact on an evo!
I got the brakes brown finally.. I had no problem with fade. The brakes stayed strong the whole race.. I may have not been as aggressive as someone with more experience under there belt.
I will post ride height This weekend.. Thanks for the advice..
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
outsider
27
Dec 14, 2004 08:24 AM
spyderx
16
Sep 20, 2004 04:22 PM
EVO Rosso
15
Jun 14, 2003 11:04 PM
