How Much Rear Wing Riser Height for APR GTC300 ??
Hi,
I've got an Evo VIII track car. I'm running it with suspension, engine and tranny mods. I have an APR front splitter and just got an APR GTC300 61" wing, because I need more rear downforce.
To be honest, at its 12" (or so) riser height it does not seem nearly high enough, and no where near the roof line.
What has been YOUR experience for recommended wing heights for the Evo for track use???
Thanks
Thanks
GTC300 and GTC500 are both the same riser height.
The car is getting loose on medium and high speed corners.
I can't take corners "fast", of course, it's 3250# w/o driver.
(Then again, I got used to tracking a Diasio this past season.)
Apr gtc 300 risers
So I've done a whole lot of looking..does anyone know if there are extended risers for the 300..I know it's 13 inches high but I wouldn't mind a little more hight. And it's Goin on the Evo x. Thanks
Pm if ya can
Pm if ya can
They do exist I had looked for them years ago but in the end never got them. Looking around again I'm not seeing them on the usual sites. I would contact someone like driveline motoring or any of the main shops that carry APR and they should be able to get it for you. The GTC 300 is a 3D wing meant to work in "dirty" air....raising it up closer to the roof line may/may not make it perform better.
APR discontinued the GTC-300 wing risers and no longer makes or offers them.
I found that out when looking for risers on my Evo 8 with GTC-300 wing. I actually just ordered a GTC-300 wing for my Evo X and should have mine on soon
If you a bigger/ taller wing to sit above the roof line then Kognition would be the wing I would pick. Its designed to perform better in cleaner air.
You are correct on the wing being designed to work in "dirty" air since its a 3D designed wing. APR developed it to work just below the roof line and racing it up above the roof line actually hurts its performance a bit.
KFC-AWD
May 27, 2016 11:24 AM
FS[West]: APR GTC300 with riser and gurney flap
guyver858
May 5, 2015 08:23 PM
